Wow! All this technology and speculation. On sunny Sunday noon......just go outside and look up.....any shade?
Production dips at mid-day
All you have to do is hit the play back button in the solaredge view and yu will see the wattage dim on the array through the past day or week.
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Originally posted by ButchDeal View PostAll you have to do is hit the play back button in the solaredge view and yu will see the wattage dim on the array through the past day or week.Comment
Originally posted by rmk9785e View Post
I'm sorry but I don't see a playback button on the iphone app or the browser monitoring site. I hope it's not too obvious.
Yo u might no have full access.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Originally posted by bcroe View PostShading happens, but it should be obvious. A narrow streak can knock out a lot of panels.
Are you running micro inverters? If so, high line voltage could cause some of them to trip
out as production tries to rise, sort of a self limiting thing. This should be easy to check as well.
Bruce RoeComment
A multimeter works. A data logger is better. If you complain enough the utility has recording power meters that they grudgingly can install. By law they need to maintain a certain range of voltage and in some cases local conditions on their grid can raise havoc on the voltage. Capacitor banks and local generation can cause it. Frequently they really do not want to deal with it and you may need to contact you state PUC to encourage them (or at least hold out that option). String Inverters usually can have their voltage range widened by using a factory password but my guess is microinverters are fixed.
Before you do it definitely rule out shading.Comment
It’s def not shading, and during that 1.5 hour time frame when I playback the video the panels blackout in no particular order (as if powering down randomly), and then come back to working order. It’s bizarre. I have a work order in, who knows when they will get to me. I just wanted to learn as much as I can about what it could possibly be. Thank you for your input!Comment
Originally posted by Flashola View Post
How would one check this, and can it be fixed? I’m having the same issue.
ramp up. Next measure it where the inverters plug in, it will be higher when they
come on. Find out the length, wire gauge, and conducted current from the micro
inverters to the feed to your box. Look up wire resistance per foot and use ohms
law to calculate what voltage rise is generated in the loop. My loop was originally
generating 9V added to the line voltage. Summer 2020 I fixed that and gained 77%
better wire efficiency by replacing 4 gauge copper with 4/0 aluminum. Bruce RoeComment
