I came across 36- new 210 watt panels that are 48 volt putting out 68 volt that were made in 2010 by a name brand company. they seem to be some sort of R/D panels as I can not find and info on them at all. I do have to install the connector boxes to them but all came with them... then I came across 70- new 48 volt batt back up batt modules that have eight 12 volt 9ah batt each in a nice metal box with plug in connectors.. so that would be 72 ah x 70= 5040 ah total.. so I am looking at the outback 3600 48 volt inverter x 2 . so I can grid tie then use the system if the grid goes down.. any ideas , as all the parts I have so far are on the odd side
48 volt 210 watt panels Options for my diff parts
If these modules are to be placed on your home or an insured building make sure there is a UL or equal listing or certification and CE doesn't count.NABCEP certified Technical Sales Professional
Panel cirts
I own my home free and clear and the panels will be on the ground also all panels have embedded s/n that when i call on them they show as 12 volt but are not that. And it does show ul listed , and has cirts.
i came across 36- new 210 watt panels that are 48 volt putting out 68 volt that were made in 2010 by a name brand company. They seem to be some sort of r/d panels as i can not find and info on them at all. I do have to install the connector boxes to them but all came with them... Then i came across 70- new 48 volt batt back up batt modules that have eight 12 volt 9ah batt each in a nice metal box with plug in connectors.. So that would be 72 ah x 70= 5040 ah total.. So i am looking at the outback 3600 48 volt inverter x 2 . So i can grid tie then use the system if the grid goes down.. Any ideas , as all the parts i have so far are on the odd sideComment
have a chat with UL or whatever listing lab they are certified with. I am getting mixed signals here. If they are listed for one voltage but producing another voltage there is something wrong with either the listing number or something else. Even if you don't have a mortgage you have much to lose with unlisted modules no matter how good the deal on them was. Think of a fire and no insurance coverage. This is worst case but within the realm of possibility with unlisted (read prototype) modules.NABCEP certified Technical Sales Professional
All solar panels i have tested rate higher then what it is rateted for
have a chat with UL or whatever listing lab they are certified with. I am getting mixed signals here. If they are listed for one voltage but producing another voltage there is something wrong with either the listing number or something else. Even if you don't have a mortgage you have much to lose with unlisted modules no matter how good the deal on them was. Think of a fire and no insurance coverage. This is worst case but within the realm of possibility with unlisted (read prototype) modules.Comment
All solar panels i have tested rate higher then what it is rateted for exergreen panels tahe are called by evergreen 12 volt but put out 21 to 22 volt output not under load.. the panels i have putout 66 to 68 volts, under no load.. it looks like this panel was never released for sale in the US. all are new all have s/n and were made less then 6 months ago. when I test for watt most put out 220 to 230 watt not under load..
Under no load, your voltage is correct, a slightly higher voltage, and then when proper load is applied, the panel voltage drops to it's rated voltage.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
amps x volts = watts
Measure open ckt voltage
measure short ckt amps
multiply, and take 10% off the result, and you will be very close
With homebrew gear, you cannot easily measure Vpmax or Ipmax
But there is no such thing as Watts under no load. That's like measuring MPG on a car sitting in the driveway.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The inverter i want
I came across 36- new 210 watt panels that are 48 volt putting out 68 volt that were made in 2010 by a name brand company. they seem to be some sort of R/D panels as I can not find and info on them at all. I do have to install the connector boxes to them but all came with them... then I came across 70- new 48 volt batt back up batt modules that have eight 12 volt 9ah batt each in a nice metal box with plug in connectors.. so that would be 72 ah x 70= 5040 ah total.. so I am looking at the outback 3600 48 volt inverter x 2 . so I can grid tie then use the system if the grid goes down.. any ideas , as all the parts I have so far are on the odd sideComment
All the Large 60-80A MPPT chargers from Xantrex, Outback, Morningstar and Midnight are in the ~$500 range. They all work well. You can buy PWM chargers for a lot less, but you loose a lot of power without the DC-DC conversion the MPPT does. There there is ebay and off-name brands which may only be 60% efficient, compared to the 95% big name efficiency. One tester reported a piece of wire has less loss, than a knockoff MPPT controller, it was so bad.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
