Mandatory Renewables
Why are the levels of cleanliness required unrealistic? Given that cars are more powerful than ever, safer than ever, cleaner than ever, more efficient than ever, and cost about the same (in real dollars) of cars 30 years ago, it sounds like the standards are pretty realistic. They're certainly not crippling cars or making them unaffordable.
Right. Cars are checked pretty thoroughly when they are new, and from then on most smog check stations rely on OBD-II (or similar) diagnostics to ensure that the system is still working. Saves a lot of money that way.
OBD is an interesting example of things going wrong- there used to be 5 protocol flavors in the world for that: 1 for Asian cars, 1 for European and 3- for US made . 3 big US automakers (Ford, GM, Chrysler) couldn't agree on the common protocol standard and each implemented their own and incompatible one. Somehow Asian car makers didn't do that and all Toyotas, Nissans, Subarus, Hondas, Hyundais 'speak' the same protocol albeit different from any of 3 used by US makers.Comment
Average engine power in US cars in 2009 - 247hp
1968 Shelby Mustang, Police Interceptor version (biggest engine available) - 350hp
2017 Shelby GTE - 456hp
1969 Chevy Camaro ZL1 - 430hp
2016 Chevy Camaro ZL1 - 650hp
1970 Olds 442 - 370hp
Tesla P100D - 532hp
Google "horsepower-has-increased-112-since-1980-and-other-fun-facts" for more info.Last edited by jflorey2; 07-19-2017, 12:42 AM.Comment
Efficiency - no, that was primarily CAFE. The car companies screamed bloody murder when the first CAFE rules came out, and claimed that CAFE requirements would bankrupt them and "would restrict the industry to producing subcompact size cars - or even smaller ones" - US cars would become "all sub-Pinto sized vehicles." This was in 1974, and I notice an awful lot of SUV's on the road.
Safety - no, that was primarily NTSB recommendations and DOT requirements.
Cleanliness - again no. And again the industry fought them tooth and nail. Ford claimed that if the "EPA does not suspend the catalytic converter rule, it will cause Ford to shut down." That was in 1972. Ford seems to still be around.
BTW, smog stations don't rely on OBD and use gas probes to analyze the actual content of the exhaust which is a good thing.
Most all of the late sixties and early seventies era muscle cars were underrated for insurance reasons. You really think a 426 Hemi only put out 425 horsepower? The ZL1 would dyno 550hp. Not to mention enough torque to slow the rotation of the Earth. Couple that with a modern 6-speed automatic transmission and the newer Tire compounds you'd be changing your shorts for sure. As far as Tesla goes that's only good for about 2 minutes before it goes into save myself mode. Not to take away from Modern American Muscle it's still quite impressive. and none of the oldie but goodies used forced induction.Comment
The best deal in high octane gasoline is down at the air strip. they chuckle when I bring in the boat and fill it up with 100 low lead.Comment
Power - yes, that was simple competition.
OK, they may do things differently in your neck of the woods. Down here the smog check on a modern car (when required) uses a scanner.
My neck of the woods are California / US (present) and Ontario / Canada. In both cases smog stations stick gas probe into tailpipe and measure exhaust content. OBD does not have relevant data for the simple reason that cars don't have relevant sensors. No amount of scanning would produce what is missing. The station 'scans' OBD for the list of stored error codes, that's all they can possibly do. The error codes would look like: 0402 "O2 sensor slow response bank 1". I just made this DTC up, too lazy to look up the real one but the point is OBD does not have the data you think it does.Comment
My neck of the woods are California / US (present) and Ontario / Canada. In both cases smog stations stick gas probe into tailpipe and measure exhaust content. OBD does not have relevant data for the simple reason that cars don't have relevant sensors. No amount of scanning would produce what is missing. The station 'scans' OBD for the list of stored error codes, that's all they can possibly do. The error codes would look like: 0402 "O2 sensor slow response bank 1". I just made this DTC up, too lazy to look up the real one but the point is OBD does not have the data you think it does.Smog Check Program's Updated Test Technology
Californians getting Smog Checks today may notice that the traditional tailpipe test used for many years has been replaced by a quicker, computer-based test for gasoline-powered cars model-year 2000 and newer, and for most diesel vehicles that are model-year 1998 and newer.
This updated test uses the diagnostic capabilities of the vehicle's computer system instead of the traditional tailpipe probe to measure the vehicle's emissions. This On-Board Diagnostic (OBD) system gathers information and determines if the vehicle's emission control systems are operating properly. A visual inspection of emission control components is still required as well.
The OBD only method of testing vehicles is the result of 2010 legislation (AB 2289-Eng) which is designed to improve the Smog Check Program and further reduce air pollution. The Smog Check program removes hundreds of tons of smog-forming pollutants from California's air every day.
Gasoline-powered vehicles model-year 1999 and older will continue to receive Smog Checks using a tailpipe probe as well as the OBD test.
CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
From CA's smogcheck site:Comment
I'd argue efficiency rush was triggered by gas prices hikes so no government intervention was required. What you're referring to is politics and that is fascinating subject but all those improvements (except safety) were made possible by drastic change in design- instead of carburetor based cars car makers went with injection based ones which immediately made AFR control much more precise.
AB 2289 was the law that allowed OBDII-testing only in California for cars manufactured after 2000. Here's a blurb on it from smogtipsc.com:
2000 model year and newer vehicles (except for vehicles 14,000 GVWR or greater) no longer require the tailpipe portion of the smog inspection.
Late model vehicles (along with diesel vehicles, 1998 & newer and which are 14,000 GVWR or under) will be administered the new On-Board Diagnostic (OBD) Inspection System (OIS) instead of having their exhaust emission analyzed while being driven on a dynamometer. The existing visual and functional test portions of the smog inspection will still apply.
(* - the one exception was Honda's CVCC engine, which could achieve CARB levels without a catalytic converter.)Comment
OK, they may do things differently in your neck of the woods. Down here the smog check on a modern car (when required) uses a scanner.Last edited by Sunking; 07-19-2017, 07:35 PM.MSEE, PEComment
20 years ago I moved to California and had to go to a regular automotive repair shop to get smog tested. They didn't care that the air pump was removed. ( air injection reactor)
Didn't care that I had Hooker Headers. Passed the tailpipe sniff test with flying colors. And then told me I failed because I had two catalytic converters instead of one. Needless to say I moved to Catalina Island for a spell, and drove a golf cart, then got the hell out of Dodge and never looked back!Comment
If you talk to any small engine mechanic, you learn never ever use gasoline with ethanol. Honda, Stihl, and Echo even warn against using ethanol. Pure gas with 89 octane Even your vehicle engine will do much better without it.Last edited by Sunking; 07-19-2017, 08:09 PM.MSEE, PEComment
