That you're not going to do, unless you can transmute matter cheaply. Coal contains uranium, thorium, cadmium, lead etc and all that waste has to go somewhere. You can get it out of the flue gases - but then you have to put it somewhere. You can put it in storage pits - but then it leaks into ground water. You can put it into lined, sealed pits - but then you're going to need a LOT of real estate.
That's easier, because the volume of waste is so low - and it IS possible to transmute those volumes (or store them more easily, or reprocess them.) But the question is still - who will pay for it? Two AP1100 reactors in South Carolina were just cancelled because of cost overruns; they simply couldn't afford to build them. I'm all for cheap/safe nuclear power, but we're a ways from that right now.
Agreed. We will have both in some form for a while, although absent some technological breakthroughs they will decline with time due to costs.
find ways to neutralize & dispose of your nuclear waste.
Totally walking away from those power sources is not a good idea so find ways to use them as best as you can.
