Hi there, new to the forum. I have an issue with a solar panel. I've tried google searching but cannot find a topic with the same issue. I have a 130 watt solar panel. Whenever it starts to produce more than 8 watts the amperage starts to pulse back and forth from 0 to whatever the output amps is. When the amperage output is below 8 it has a nice steady output. When the amperage is pulsing the voltage is staying stable. Anyone have an idea as to what could cause this? And is it possible to fix?
Thanks
Andrew
Thanks
Andrew
