Hey all, I'm in the process of installing my system, and I've bumped into a frustrating problem: Conduit.
I'm installing a 9.4KW Solaredge system. I have about a 30' run from my soladeck, through the attic, and down the back wall of my house from the eave to my main panel.
Here's what I'm up against.
1. If my math is right, I have to run 1 1/4" conduit (3 strings, so 6 10 gauge PV wires + 10 gauge ground).
2. I don't have access to a EMT bender of this size, and they're $300+ to buy one.
3. I'm not really clear on what connectors I need in order to do it right. For example, I don't see any way to keep the conduit inside my 2x4 rafters directly below the soladeck.
Since I don't have access to a bender, I'm inclined to use FMC instead of EMT.
My questions:
1. Is there an issue with coming out from the soladeck with a straight fitting and looping back up into the rafters, or do I need an elbow of some sort to keep the conduit contained within the rafter space?
2. Do I need to run watertight conduit for any/all of the run? I'm assuming inside the attic won't need to be, since it's in a sealed area and running from a watertight box on the roof, but once I get outside the eaves, do I need to make a transition to watertight conduit and fittings?
3. My inverter's instructions only have info on attaching with 3/4 or 1" conduit. Any advice on how to attach to the inverter? (Solaredge SE10000A)
Any advice you can give is welcomed. I'm a noob to running conduit, and it's ridiculous that this is the one area of the install I'm really struggling with.
Thanks!
My questions:
Thanks!
