Time to replace my 25 year old elec water heater.... no leaks at present but it's bound to fail soon. Expect to install a 5kw grid-tied system this year. What would the optimal setup be to run an elec water heater.... I'm figuring put it on a timer to heat during the day. What kind of on/off cycle time can I expect.... If it's on for , say 8 hrs a day, will it retain reasonable heat for the other 16 hrs? Or cycle it on/off 4 times a day?
I don't use a lot of water, just me in the house, so figure one daily shower (early afternoon) and the usual kitchen use. I've been using about 180 kwh/month for the water heater.... it's a big one, 80 gal, sized for the garden bath tub I rarely use. Will likely downsize to a 40 gal unit unless there are advantages to a larger one.
Natural gas isn't avail nearby, Propane is much higher cost than elec for water, so I'll stick with elec.
What type of setup (size, timers) works well in combination with solar? Thanks.
