Hello!
We recently had our solar installed a little over 2 months ago. No issues until about 2 weeks ago, when the inverter was off in the morning with the Fault light solid red, no display. Cycled the power and it went through it's normal bootup and came on. Then the exact same thing has happened 2 more times since. All 3 times it is in the morning, and must happen at start-up since there is no power generated at all when this happens. There are no error codes logged - our installer talked to SolarEdge and they see nothing logged on their end either, so it's a bit of a mystery.
Curious if anyone else has had a similar issue and what the cause may be?
Thanks!
Thanks!
