I have been using an 1250 / 2500 watt inverter and a single 105 AMP-HR battery to build a spec house (no power yet). I run up to 4 compact flourescents and various power tools all day long, then bring the battery home each day to charge. I have also used a smaller inverter to power a few things our house (computer, TV, lights) when we lose power, which happens quite frequently here in the sticks.
My question is: Wouldn't a battery-inverter combination serve the purpose that many people buy a backup generator for? It would seem like if you have installed a 115 V well pump and don't use electric appliances (stove, hot water heater, etc.), you could certainly run a few lights, computer, one fridge and the well pump for at least a half-day or so if you had four 100 AMP-HR batteries. If the power outage was longer, you could start a vehicle and charge the batteries to keep the fridge going.
I know a generator would probably be cheaper and also allow 220 volts, but my ulterior motive would be to have the start of a PV system. Plus, I hate the sound and smell of a generator. With just my single battery setup I'm using now, I have a feel for how much energy (KWH) is available from a single battery.
