Below are plots of the power, voltage, and current from three individual MPPTs of my daughter's 10.53kW system on a cloudless day. The system consists 39ea 270W panels in 3 separate 13-panel strings connected to 3 of the 4 MPPTs in her two SB6000TL-US-22 inverters. One string faces ~East (~100 degrees - red), one faces ~South (~190 degrees - fuchsia), and the other faces ~West (~275 degrees - blue). The East and West strings are unobstructed but a chimney shadow sweeps across the South string until about 11:00AM every morning. I believe if the South string weren't shadowed its morning power curve would rise a little faster and certainly be smoother, but I was actually expecting to see something much worse than what the power plot is actually showing. Do you think the downward spikes and stair steps might indicate that OptiTrac is locating new power points about every 30 minutes (it's actually set to 6 minutes) as the shadow moves or is that just the way any tracker works under such conditions? As you can see from the voltage plot, the voltage doesn't actually reach the voltage of the other two strings until the shadowing stops around 11:30. I know I could temporarily disable OptiTrac just to see if there is any difference but I don't actually have convenient access to my daughter's system. What do you think about this performance and how much better do you think the South string might perform without the shadowing (not that that's actually an option!)?
Thanks,
Ray
Thanks,
Ray
