Some violence in the voltage in the morning and evening seems to be a normal side effect of MPPT... there isn't much power there, to the optimization routine has a harder time figure out where to operate. Here is an example from a single panel on my system, showing voltage and power on an otherwise clear day. I have some structural shade in the afternoon, but the morning is about as clear as it can be in a residential area without a perfectly clear view to the horizon. V on 2-15.JPG
The mpp voltage on your SE and SW arrays is probably not as different as you are imagining, and the mismatch won't amount to much in the way of losses... voltage is only weakly affected by the irradiance, and is much more strongly affected by temperature. Current, on the other hand, is much more sensitive to irradiance than to temperature.
Before SMA got into the multiple MPPT game, they aggressively defended the idea of multiple orientations in parallel on a single MPPT (as long as the strings were of equal length). One study showed a mismatch power loss of only 0.25%. In your case, that could easily be wiped out by the difference in efficiency from the MPPT loading.
http://www.smainverted.com/files/201...-TEN122510.pdf
With respect to your daughter's system, there isn't a problem, really. A lightly loaded inverter will have a different efficiency than one more heavily loaded, and from curves I've seen, once you drop below 20% loading the efficiency starts to fall off quickly. In other words, especially in the morning and evening when there isn't much sun, the inverter efficiency is probably a bigger deal than voltage mismatch in the panels. I'm not sure if there is any benefit to jumping the two MPPT's together in her case, but that is an option available in installations that require only a single mppt.
Efficiency test data on the SB6000TL-US-22 is available, and most other inverters you might be interested in can be found here:
http://www.gosolarcalifornia.org/equ...ests/summaries
