I have a 4' x10' solar collector (active hot water system) on my roof that has a hole in one of the header pipes. I would like to remove the glass top to try to repair this myself as local companies want to charge me over $1300 to rebuild it! Having never tackled this before I am concerned the glass will be difficult to remove off a panel that been up on the roof for 20+ years. I dont want to break the glass! Any suggestions, ideas or advice on this?
solar collector glass removal help needed
Hi greggo - Welcome to Solar Panel Talk!
Sounds like quite a project! Having never tried anything like that I am short on suggestions but hopefully someone can give some ideas!
The 1300$ certainly gives you some incentive and something to work with.
Russ[SIGPIC][/SIGPIC] -
check the prices for a replacement collector at solarroofs.com 20 years is getting long on the lifetime of a water collector. When you repair one header, the next week the other header needs a repair, then a tube ........
The glass is likely tempered glass, and a slight tap or scratch on it, can cause the whole thing to shatter. Be careful.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
