Hello,
When we purchased our home eight years ago, it had a 17 year old solar hot water system that included a 120 gallon tank and three solar panels. We've used it successfully in conjunction with an auxiliary gas powered water heater ever since. But now, the system is 25 years old, the tank is in bad shape, and the pump, expansion tank, sensors, valves, etc are rusty, crusty creatures. The cost of replacing everything is too high for us to justify with our current budget, so we have had the tank drained, the glycol drained, and the tank and associated equipment removed. Only the solar panels and insulated piping for the glycol remain on the roof.
Questions:
Is there any possibility that the solar panels will generate heat to the glycol piping (that has been drained) and insulation that would cause a dangerous situation, similar to a tea kettle without any water in it sitting on a heated stove burner? What would be the best way to avoid such a problem?
How could I determine what value if any the solar panels might have? They are vintage 1985 but still in good shape.
Thanks.
Peter
Questions:
Thanks.
Peter
