My solar system is going to be installed probably end of December. My roof is 11 years old, asphalt shingles, warranty on the roof is supposedly 25 years although 2 homes in a development of about 75 homes have already re-shingled (presumably because of problems/leaks, but I'm not sure).
I wish my house had "lifetime" shingles, but that wasn't an option at the time.
I could put on "lifetime" shingles right now, before my solar panels are installed, but of course that means shelling out a lot of money that I might not have otherwise needed to spend for 10 to 15 years.
I could wait the 10 to 15 years that are supposedly left on my existing shingles, at which point I'd have to remove the panels, re-shingle, then reinstall the panels. My installer said they charge $1500/day (2-day minimum) for the service of moving the panels temporarily to the other side of the roof while your roofer re-shingles, then moving them back after the re-shingling. Total cost of $3,000 just to have the solar panels moved.
But the thing is, I'm a real do-it-yourselfer. I've done roofing before, and I would most likely want to re-shingle my roof myself. So the question is - how hard would it be to do the solar panel move and reinstall myself? Is it worth $3,000 for a pro to do this? If you were doing this yourself, would you try to use the same exact lag bolt holes that were used originally? If so, how? (you won't be able to see them after the new shingles are in place). If not, would you need a specialized stud finder to find those trusses? I have a feeling my cheapie stud finder is not good enough to ensure I hit the center of those trusses and if I miss, its a major mistake requiring a new shingle.
