Creating a kiosk
As enticing as it may seem to go directly into the computer, the expense of a car/airline charger that will work off between 10V and 18V is small compared to the risk of damage to the device from going direct.Last edited by inetdog; 11-17-2014, 10:50 PM.Comment
I didn't post that....
The part that says it is a quote by SunKing is *part* of my post.
Mods - something has gone badly wrong with this website - you need to look into what happened that posts are getting corrupted.Comment
Hello
I am looking at creating a solar kiosk to be used for charging up to 10 mobile phones.
I am very new to solar panels etc. so i was hoping you could assist me. I have the following questions:
If i use a solar panel with a peak power of 30W, would that be sufficient or should i get 2x 30W panels?
How would i connect a usb mobile phone charger to the solar panel?
Is there a chance that too much power will be generated and a phone battery might get damaged?
thank you in advance
Johan
It is basically an 80 watt solar panel (should have gone with a 100watt) with a small 10Amp PWM Charge controller. The 12volt battery is a Blue Top Optima 65Ah and a simple 200watt inverter. The hand cart is something I got from Harbor Freight and the battery box can be found on Amazon or Ebay.
It packs up to a small footprint and is easy to transport unless the ground is real sandy or muddy.
Small Portable PV sys pic3.jpgSmall Portable PV sys pic2.jpgSmall Portable PV sys.jpgComment
