12 volt photocell switch??
12 volt DC NIGHT WATCHMAN PHOTOSWITCH
at backwoods solar $40
http://www.backwoodssolar.com/catalo...%20PHOTOSWITCH
10A @ 12VDC
Bought one myself, but have not installed it yetPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hi, I guess you mean 12 volt dc try a Search for CellOptik 12v DC.Comment
Hi Des - Welcome to Solar Panel Talk!
Good link! I have looked for the things in the past and come up short.
Russ[SIGPIC][/SIGPIC]Comment
MorningStar makes a solar charge controller with a dusk-dawn lighting output. Also has timers in it for more flexible uses.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If someone wants a cheaper controller (Morningstar is proved quality though) can try searching for solar street light in ebay and get something like this in the 20USD range:http://cgi.ebay.com/10A-Solar-Street...item1c17e68f9a
If you want to set a heavy load you would like to use an additional 12V relay.
I use one of those for my mini solar genset battery charge and night light for the genset area.Comment
