Duel fuel Hybrid heatpump?
  • DanS26
    • Dec 2011
    • 991
    The OP is burning 800 gal a year. He is the poster boy to buy a 1000 gal tank. As most of you know a 1,000 tank only holds 800 gal of propane. Fill once a year during summer fill rates.
    If he can do some conservation and only burn 600 to 700 gal he has a reserve to make it to summer even after a hard winter.
    If he has a propane water heater, I suggest he install a Nyle system to use up some of that banked kWh. (use a timer)
    Replace the propane clothes dryer with electric, same with the oven and cooktop.
    Buy an EV.
      Originally posted by Mb190e
      Spot price plus.
      1 - 200 gal. + $2.05 per gal.
      201 - 400 gal. + $1.20 per gal.
      401 - 700 gal. + $ .65 per gal.
      701 - 1500 gal. + $ .55 per gal.
      1501 - 2999 gal. + $ .35 per gal.
      3000 gal. +. + $ .35 per gal.
      I'm also guessing if I could get my use down to around 400 gallons I could get my 500 gallon tank filled up once in the summer. Which I already do but then I get it filled up again sometime around Christmas or New Year's and then again and February or March
      Get a 3000 gallon tank - that is far cheaper than anything else.
      • Mb190e
        • May 2014
        • 167
        I already own my own 500 gallon propane tank. I bought it and had it installed underground when we bought the house. I wanted to go with the 1000 gallon tank but the price was almost double the 500 which was already $2200. I agree the leasing companies are far worse and you're stuck buying propane from them. The leasing companies always seem to deliver propane when the price is the highest. I am a will call customer. I can buy it from whoever I want, the co-op just happens to be the cheapest. I have a propane hot water heater, thought about getting a heatpump hybrid hot water heater, I think that has the least amount of payback. I already have a electric cooktop and electric clothes dryer. Although I have recently started using a clothesline after the solar panels were installed which is reduced our use some. Thanks for all the replies this is a very interesting discussion.
        • Mb190e
          • May 2014
          • 167
          Buy an EV.
          I just looked up the Nile system that's perfect for the hot water heater without buying a whole new unit.
          • Mb190e
            • May 2014
            • 167
            Okay I have some people coming this week to give me a quote on a hybrid heatpump. We'll see if this is going to be a cost-effective option.
            • DanS26
              • Dec 2011
              • 991
              The Nyle is also rated a 1 ton AC. I connected my Nyle to my cold air duct system. It works great. Not so good in cold weather but in spring summer and fall it can't be beat.
              • Mb190e
                • May 2014
                • 167
                I received a couple quotes for the heat pump/air-conditioner still waiting on a couple more one is for a Train 3 ton 13 seer $4900 installed and the other is a carrier 3ton 13 seer for $4100 installed. Both of these quotes include line set, coil and thermostat.
                • Willy T
                  • Jun 2014
                  • 405
                  Sounds like 2 good quotes. Both are quality units. I don't know your house, but the thermostat selection may give you some options to use remote sensors to keep the rooms more balanced. I had one central location that created a lag in both heating and cooling and with remote it stays more balanced and runs less.
                    A SEER of 13 isn't very high.
                    • Willy T
                      • Jun 2014
                      • 405
                      Your right, but when you have a bunch of KWH to dump and it fits your budget, it might beat paying a premium price. In my case they wanted $1,000 more for each step up in efficiency that I would never get my $$ back on.
                      15 seer cost $1,000 more but saves $8/month, in one year = $96/yr
                      Where he lives he might save more, Seer ratings are like mpg on autos. Kinda depends on how much you drive to calculate savings.
                      This will do the savings.
                        Just be aware that one is locking in a price/cost for a long time to come.
                        • Mb190e
                          • May 2014
                          • 167
                          I wanted to get a 16 seer unit but, the guy that I'm talking to right now, says anything above the 13 is going to be a waste of money because I only have a single stage blower on my furnace.
                          • Willy T
                            • Jun 2014
                            • 405
                            There you go, there is so much that goes into the SEER rating that people do not understand. It's like tuning a race car to make one qualifying lap. Then comes the efficiency loss after the first few year's with oil transfer on the internal exchange surfaces on the coils and a lot of the ratings go away. The first 7 minutes of the on cycle will be the same on with the same compressor system, after that the higher SEER unit will start save some ( on a 10 minute cycle you save for 3 minutes ). If the unit cycles often you will never see any savings. Since you have to buy in 1/2 ton increments you end up with to large a unit or to small ( small can be ok, more savings to a point, if it runs to long you lose because of heat gain ). The ducting and back pressure on the system is important also.
                            • Mb190e
                              • May 2014
                              • 167
                              Okay getting the new carrier 13 seer AC/Heatpump installed in a couple weeks $4000 for everything except the indoor thermostat. I have already purchased and installed a Nest capable of doing 2 heat 1 cool. We'll see how it goes come October, November.
                                • 5213
                                Heat pump
                                That is what I am negotiating for here. I don't follow the issue of the blower, even
                                it its that important, could you change the pulley? My last 2 high efficiency furnaces
                                have multi speed direct drive motors. My plan is have a separate thermostat for
                                the unit, with a blower signal going over to my propane furnace setup. The propane
                                is my backup for outages; otherwise do zone electric when it is too cold for an air
                                to air heat pump. Bruce Roe
