De-Icer?
  • Sharich
    • May 2014
    • 9
    De-Icer?
    Living in the Great North East, we have snow. Last winter I had a couple of weeks that I couldn't use my solar due to the snow.
    At 70+ I don't see me getting out a ladder and shoveling off the panels. I was thinking of using my pump crop sprayer with car windshield deicer to clear the panels, the spray reaches.
    Would this harm the glass?
    Sharich
    The deicer solution needs to be guaranteed to not damage the surface or seals of the panels. For example - Rain-X says they have not tested their solution on solar panels so refuse to comment.
    • Sharich
      • May 2014
      • 9
      De-Icer
      Thanks', any other thoughts?
      • mapmaker
        • Aug 2012
        • 353
        The engineers over at Midnite have played around with pumping power back into the panels to heat them up. There are a few discussions on their forum. It does work. It doesn't seem to have caught on in the industry. Maybe its not cost effective... Perhaps we need a govt program to stimulate the panel warming industry
        --mapmaker
        ob 3524, FM60, ePanel, 4 L16, 4 x 235 watt panels
          Solar panels can generate power, or use power. Trick is if you want to heat them takes a DC source with a voltage that matches the array DC voltage. Not easy to pull off.
          • Shockah
            • Nov 2013
            • 569
            --mapmaker
            hehe...
            [CENTER]SunLight @ Night[/CENTER]
              • 5222
              Living in the Great North East, we have snow. Last winter I had a couple of weeks that I couldn't use my solar due to the snow. At 70+ I don't see me getting out a ladder and shoveling off the panels. I was thinking of using my pump crop sprayer with car windshield deicer to clear the panels, the spray reaches. Would this harm the glass? Sharich
              Exactly the same in northern IL, except I had to clear the panels about 20 times
              (just at sunrise) to keep the power flowing. Next time I'll try setting them more
              vertical, but that won't be a complete cure. Much easier with a ground mount.
              I hope to run the snow melting experiment next time, but at the least it will take
              a lot of power. My first guess is 3KW DC will let me melt 1 string of the same
              size, then go to the next string. Next year.......
              Do keep in mind, your panels may run at dangerous voltage. My snow scraper is
              11' of insulated pole. Bruce Roe
                ... My snow scraper is 11' of insulated pole. Bruce Roe
                Is that wet, insulated pole ?
                  • 15186
                  --mapmaker
                  Wait. Didn't those solar roadway panels in that "Freakin Video" have heaters in them to keep the snow off. Didn't the government help fund that research?
                    • 5222
                    At 20 below zero, no they weren't wet. Keep in mind, pure water is
                    a decent insulator, but with a low breakdown voltage. Bruce
