I just had my solar system installed last week. I had one of the companies they gave me a quote say that they use electric space heaters in the winter to use up extra production does anybody else do this?
Electric space heaters to use up excess production?
If so then your system is grossly oversized for summer![SIGPIC][/SIGPIC] -
To start off by saying my system is oversize slightly we are on the lower end of electric consumption. We use roughly 6000-6500 kWh a year. For a 2300 square-foot house family of 3. We installed and 8.1 kW system. Future plans of possibly getting solar hot water with a heatpump and/or Hot tub. Our utility does net metering where all kWh credits are settled once a year. So what I heard was if you have extra credits instead of giving them back to the utility for a penny's a kWh, use them up by heating a couple rooms with electric space heaters. I'm new to this solar PV I have only had my system for running for 5 days.Comment
In Saratoga you're going to be seeing about 3 kwhr/day average production from a 1kw AC (1.2 kw DC) system. So that's about 20kwhr/day average. Could be slightly more or less depending on array angle, roof temperatures etc.
I would definitely not try to "waste power" until you have about a year of data showing that you really have the extra power. A week of clouds can easily end a long run of overproduction and drive you back into electric-bill territory very quickly.Comment
From PV Watts for a site close to you
RESULTS
Find A Local Installer3.19 679 102 3.69 712 107 3.66 731 109 3.94 728 109 4.78 908 136 4.07 719 108 4.63 839 126 4.56 840 126 4.23 743 111 3.60 686 103 2.72 519 78 2.14 424 64 3.77 8,527 $ 1,277 Download Results: Monthly | Hourly
Caution: Photovoltaic system performance predictions calculated by PVWatts® include many inherent assumptions and uncertainties and do not reflect variations between PV technologies nor site-specific characteristics except as represented by PVWatts® inputs. For example, PV modules with better performance are not differentiated within PVWatts® from lesser performing modules. Similarly, the “Energy Value” column simply multiplies the utility-average electricity price by production. Complex utility rates and financing can significantly impact the energy value. See Help for additional guidance.
These values can be compared to get an idea of the cost-effectiveness of this system. However, system costs, system financing options (including 3rd party ownership) and complex utility rates can significantly change the relative value of the PV system.Requested Location saratoga, ny Weather Data Source GLENS FALLS AP, NY (TMY3) Latitude 43.35° N Longitude 73.62° W DC Rating 8.1 kW DC to AC Derate Factor .82 Array Type Fixed (open rack) Array Tilt 43.0° Array Azimuth 180° Average Cost of Electricity Purchased from Utility 0.15 $/kWh Cost of Electricity Generated by System 0.28 $/kWh [SIGPIC][/SIGPIC]Comment
Ok thanks, my Tilt: 33° Azimuth: 178°. I have also turn this into somewhat of a game since signing the contract for the solar panels I've also cut the cord on our DirecTV, just by unplugging 2 DVR boxes, power injector and multiroom router. It has saved me 150 watts an hour. That should equal another kilowatt a year. I just hung up my first clothesline ever. I'm attempting to dry as many close this summer via clothesline that I can. I'm pretty excited about this new adventure as of this message we have generated 136 kWh's since May 1 and it's been mostly cloudy and rainy the last 4 out of 5 days. I may have a new high today.Comment
Space heater
with a thermostat, for zone heating. Its in half the basement, heat will rise to
rooms above. I put a couple space heaters on the concrete floor at the other
end, not near anything flammable. These can be turned on to use excess
energy. If things get too cool, the lower set propane furnace thermostat cuts
in. However, it hasn't run in a couple months.
The plan is to have sufficient baseboard electric heaters to take care of
everything, each area with a local thermostat. If electric energy runs out,
they can be set lower and the propane furnace takes over. Bruce RoeComment
Something like that is happening here. I have a big permanent electric heater
rooms above.
they can be set lower and the propane furnace takes over. Bruce Roe[SIGPIC][/SIGPIC]Comment
cold might have accumulated in the summer, which is my plan. We both are looking
at a heat pump as well, some of the KWH might do a better COP than 1. Bruce RoeComment
