Tiny Structure Gives Big Boost to Solar Power
  • the captain
    • Feb 2026
    *lots of potential and early success, but more testing required:
    Researchers have found a simple and economic way to nearly triple the efficiency of organic solar cells, the cheap and flexible plastic devices that many scientists believe could be the future of solar power.
    ScienceDaily (Dec. 6, 2012) — Princeton researchers have found a simple and economical way to nearly triple the efficiency of organic solar cells, the cheap and flexible plastic devices that many scientists believe could be the future of solar power.
    The researchers, led by electrical engineer Stephen Chou, were able to increase the efficiency of the solar cells 175 percent by using a nanostructured "sandwich" of metal and plastic that collects and traps light. Chou said the technology also should increase the efficiency of conventional inorganic solar collectors, such as standard silicon solar panels, although he cautioned that his team has not yet completed research with inorganic devices.
    Chou, the Joseph C. Elgin Professor of Engineering, said the research team used nanotechnology to overcome two primary challenges that cause solar cells to lose energy: light reflecting from the cell, and the inability to fully capture light that enters the cell.
    With their new metallic sandwich, the researchers were able to address both problems. The sandwich -- called a subwavelength plasmonic cavity -- has an extraordinary ability to dampen reflection and trap light. The new technique allowed Chou's team to create a solar cell that only reflects about 4 percent of light and absorbs as much as 96 percent. It demonstrates 52 percent higher efficiency in converting light to electrical energy than a conventional solar cell.
    That is for direct sunlight. The structure achieves even more efficiency for light that strikes the solar cell at large angles, which occurs on cloudy days or when the cell is not directly facing the sun. By capturing these angled rays, the new structure boosts efficiency by an additional 81 percent, leading to the 175 percent total increase.
    Chou said the system is ready for commercial use although, as with any new product, there will be a transition period in moving from the lab to mass production.
    The physics behind the innovation is formidably complex. But the device structure, in concept, is fairly simple.
    The top layer, known as the window layer, of the new solar cell uses an incredibly fine metal mesh: the metal is 30 nanometers thick, and each hole is 175 nanometers in diameter and 25 nanometers apart. (A nanometer is a billionth of a meter and about one hundred-thousandth the width of human hair). This mesh replaces the conventional window layer typically made of a material called indium-tin-oxide (ITO).
    The mesh window layer is placed very close to the bottom layer of the sandwich, the same metal film used in conventional solar cells. In between the two metal sheets is a thin strip of semiconducting material used in solar panels. It can be any type -- silicon, plastic or gallium arsenide -- although Chou's team used an 85-nanometer-thick plastic.
    The solar cell's features -- the spacing of the mesh, the thickness of the sandwich, the diameter of the holes -- are all smaller than the wavelength of the light being collected. This is critical because light behaves in very unusual ways in subwavelength structures. Chou's team discovered that using these subwavelength structures allowed them to create a trap in which light enters, with almost no reflection, and does not leave.
    "It is like a black hole for light," Chou said. "It traps it."
    The team calls the system a "plasmonic cavity with subwavelength hole array" or PlaCSH. Photos of the surface of the PlaCSH solar cells demonstrate this light-absorbing effect: under sunlight, a standard solar power cell looks tinted in color due to light reflecting from its surface, but the PlaCSH looks deep black because of the extremely low light reflection.
    The researchers expected an increase in efficiency from the technique, "but clearly the increase we found was beyond our expectations," Chou said.
    Chou and electrical engineering graduate student Wei Ding reported their findings in the journal Optics Express, published online Nov. 2, 2012. Their work was supported in part by the Defense Advanced Research Projects Agency, the Office of Naval Research and the National Science Foundation.
    The researchers said the PlaCSH solar cells can be manufactured cost-effectively in wallpaper-size sheets. Chou's lab used "nanoimprint," a low-cost nanofabrication technique Chou invented 16 years ago, which embosses nanostructures over a large area, like printing a newspaper.
    Besides the innovative design, the work involved optimizing the system. Getting the structure exactly right "is critical to achieving high efficiency," Ding said.
    Chou said that the development could have a number of applications depending on the type of solar collector. In this series of experiments, Chou and Ding worked with solar cells made from plastic, called organic solar cells. Plastic is cheap and malleable and the technology has great promise, but it has been limited in commercial use because of organic solar cells' low efficiency.
    In addition to a direct boost to the cells' efficiency, the new nanostructured metal film also replaces the current ITO electrode that is the most expensive part of most current organic solar cells.
    "PlaCSH also is extremely bendable," Chou said. "The mechanical property of ITO is like glass; it is very brittle."
    The nanostructured metal film is also promising for silicon solar panels that now dominate the market. Because the PlaCSH sandwich captures light independent of what electricity-generating material is used as the middle layer, it should boost efficiency of silicon panels as well. It also can reduce the thickness of the silicon used in traditional silicon solar panels by a thousand-fold, which could substantially decrease manufacturing costs and allow the panels to become more flexible.
    Chou said the team plans further experiments and expects to increase the efficiency of the PlaCSH system as they refine the technology.
    How many times are you going to post this blather.
    • the captain
      what "blather"?
      do you object to this article? if so, on what grounds?
      do you disagree with the science?
      do you disagree with the results?
      do you think it's OT?
      this is from a reputable site, and the both the university and scientists involved are cited in the article. stephen chou is a professor of engineering at princeton and the project is funded in part by the united states defense advanced research projects agency, the office of naval research, and the national science foundation. the research has also been published in the journal "Optics Express" on november 2nd...
      so what is it, sunking, that you object to strongly enough to cause you to troll my post?
        Originally posted by the captain
        what "blather"?
        It is lab research that chances are will never come to anything - if it does it is 10 or more years to the market.
        It is a meaningless article (blather) by some fool blogging for hits and who may have no idea of how long the road from the R&D lab to the market is.
        Your use of the word troll indicates that anyone who doesn't see the 'light' as you do is a troll.
        • the captain
          okay, i know that arguing with admins is a bad idea, but i have to stick up for myself:
          - copied and pasted from your header for this subsection of the forum:
          "Forum: Solar energy technology
          Product innovations, new products, the latest invention that will change the solar industry"
          i don't see anything there in your description that states there must be a date at which an invention becomes viable. you and sunking would have noticed, if you had bothered to read the article, that the first thing i wrote was a disclaimer which stated that it looks promising but more research needs to be done. you have also failed to clarify that posting about lab research is forbidden. if it is, and i missed it somewhere in one of your FAQs, then i apologize, although i ask that you provide me a link to the part of the forum where you posted this.
          if you think that it was a meaningless article that was posted "by a fool" "for hits", then i ask you to tell me who you are referring to? me? science daily? the original author? a professor of engineering at one of the most recognized universities in the world? all of us? lol! that's quite an assumption on your part. what are your qualifications for disputing this research? specifics please. skepticism is healthy. baseless denial without due process... political.
          me: could care less about hits. not something to which i give even a moment's consideration.
          science daily: one of the largest science-related sites on the internet, covering a huge range of topics, including physics, medicine, cosmology, human behavior, medicine, and much more. an article such as this is only a tiny fraction of their hits. a very tiny fraction.
          stephen chou, professor of engineering at princeton: if you think he's a fool, fine. state specifically why.
          my use of the word "troll" was referring to a baseless and rude response. nowehere did i demand or even imply that he must agree with me, as you mistakenly stated. in fact, once again if you'd bothered to read it, you would have noticed that the only personal opinion of my own interjected into the article was the opening sentence, in which i expressed mild skepticism. so i guess by your definition of what makes a troll, i am calling sunking a troll for not agreeing with my skepticism.
          the real definition of troll is someone who creates conflict by illiciting responses from people with pure negativity and/or ad hominem attacks.
          i'll summarize , because you probably just ignored it the first time: this is a project backed by government money, conducted at a major university; the results of which have been peer reviewed by at least one publication. in the scientific community, this generally regarded as a good start.
          so tell me mr. admin, am i welcome here or will i now be banned for disagreeing with you, which by your definition of the word would make you a troll?
          • the captain
            p.s.
            "...Chou said the system is ready for commercial use although, as with any new product, there will be a transition period in moving from the lab to mass production..."
            call him a liar if you want. i could care less.
              Last chance - I said the original writer was an idiot in different words - not you - that we will see.
              I read the stupid article - it says nothing but green garbage for publicity purposes - publicity = funding.
              This administration is like a pack of street dogs following the green female around - they love this kind of junk and love to throw money at it saying how wonderful they are.
              The research is great and correct but it is most important to realize that the 0.1% that actually makes it to market has a long and difficult road ahead. That is one of the tasks of the government - to develop something to a point where private enterprise is willing to jump in.
              Is the government a foolish lot? Often yes without a doubt - possibly smart but often very foolish. You saying I am calling someone a liar is a bit childish - grow up.
              Like I said - last chance - the articles are useless.
              • the captain
                the study already has government funding, which i have now mentioned three times.
                i was right though wasn't i? it is political with you... it only took you two posts to start getting into it, and you've obviously honed a sharp opinion about what constitutes "green garbage", because looking through it again, i can't see a single thing that pushes any sort of environmental agenda in the article, causing me to speculate as to whether you really did read it.
                anyhow, i'm glad you gave me a last chance to not be banned for respectfully disagreeing with you (again, i called it last post), but think this exchange, as well as the one with sunking, has given me a clear message that purely scientific studies are not welcome here unless they meet some unwritten criteria (guidelines for which you failed to post a link even when politely asked). copying and pasting the exact description of this subsection obviously made no impression on you either.
                based on your first response, i had already decided that i wouldn't post any more articles here. you win. science loses. it causes me to wonder exactly what you expect people to post in a subsection that is supposedly dedicated to "inventions". you should change it to "inventions, but only if they meet the standards of russ, are in no way "green", and also are almost ready to come onto the market and are past the research stage". then it would have been clear to me russ!
                neither you nor sunking addressed a SINGLE piece of the article in a specific fashion. how easy. how lazy. you just dismissively waived your virtual hands and labeled it as "blather" or "garbage". i regret ever having wasted my time responding to you when you so clearly indicated with your initial responses that you weren't worth the effort.
                  Addressed
                    Personally, I find this sort of "research breakthrough" interesting; I just do not expect anything to come of it soon, if at all. Eventually one of these improvements will actually make it to production, and I will be able to say "I knew him when....." I do agree that articles like this should be more of an indication to look for actual published research than as an accurate description of either the technology or its applications.
                    Then there is the infamous "Popular Science" correlation, in which appearing on the cover of Popular Science magazine was the kiss of death to any new technology.
                      Interesting and the government should support such things through DARPA, universities etc. Most of the time the end product ends being something the original project never expected or included.
                      If people realize reading about advanced research is similar to reading a science fiction comic book for the most part it is OK.
                        This is one of those. The researchers were looking for a way to reduce the ~8% power loss caused by reflection on a panel that does not have anti-reflection coating. Instead they found that the photons stuck around long enough to have a much greater chance of knocking loose an electron once they got in.
                        The one thing that I have the most reservations about is that inorganic (silicon) PV may have a more exact energy level requirement that makes it less likely that the trapped light will convert before it loses its energy in other ways. The researchers' testing with silicon (or other inorganic) PV will be the next big step to look for.
