Lighting the dark (night) areas on earth with sun light conveyed from bright areas?
So when are you going to cough up around $1 Billion dollars to do that?MSEE, PEComment
A functional and useful unit was NOT implemented twenty years back - a toy like DIY panels may have been.
Positioning equipment in orbit is not so easy as you might suggest - solar sail (not sale - that is Walmart) is of marginal use in some cases.
Totally a useless proposition - you must be one of the loony left voters?[SIGPIC][/SIGPIC]Comment
Can not find any budget information on Russian Znamya satellites, but Japanese IKAROS, which was driven by solar sail, which is basically a big mirror, did cost 16 million to build. This is cost of average research project.Comment
You must be a freaking internet telepath, ah?
You may mumble whatever you want, dude, but orbital mirrors and solar sails are not a fiction, but ongoing research, and probably better investment than those multimillion few megawatts solar power plants which were build plenty during recent years.Comment
You are talking about toys 'dude'. I spent a lifetime working on projects - what you so easily throw out as you have no idea what you are talking about happens to be important. Like I said - 2525 and you can make book on that. Scaling up from toy to major is never straight forward and never easy - not to mention how many tons of space junk are flying by up there to shred any large object.
Green fuzzy headed thinking is useless stuff.[SIGPIC][/SIGPIC]Comment
In most cases it won't make sense financially. But if you had a big city that could be lit this way it might make a lot of sense.
Let's look at LA. Over 2 million streetlights. Let's assume each streetlight costs about $2000 to install. That's 4 billion dollars in capital costs - and $100 million in power costs per year - the city could save. Could 4 billion buy a heliostat in geosynchronous orbit? Well, a Delta IV Heavy launch will set you back about $250 million and will deliver 12 metric tons to GTO. That leaves 3.75 billion for the heliostat itself - and that could pay for a lot of development.Comment
Not in my city thank you. I am one of those people who cannot sleep when it is light out. There is a reason God made day and night. One of them is so I can sleep.MSEE, PEComment
I don't know that it would be much different from having a streetlight near your house. But that issue (light pollution) would definitely be a concern.Comment
Anyway the whole subject is pointless. To do it would require a geosynchronous orbit at 25,000 miles above the earth. The reflector would have to be enormous the size of a small state to reflect enough light to the surface to illuminate a single city with dim light . It is pure fantasy of a Sci-Fi book.
It would also be seen as a weapon of mass destruction. If you have enough precision to position it and keep it perfectly flat, you can change the shape to parabolic to concentrate the light onto a small area like a city block and vaporize it in a few seconds.MSEE, PEComment
Anyway the whole subject is pointless. To do it would require a geosynchronous orbit at 25,000 miles above the earth. The reflector would have to be enormous the size of a small state to reflect enough light to the surface to illuminate a single city with dim light.
It would also be seen as a weapon of mass destruction. If you have enough precision to position it and keep it perfectly flat, you can change the shape to parabolic to concentrate the light onto a small area like a city block and vaporize it in a few seconds.Comment
Would you say the required Federal Specification of Interstate Highways passing through a metropolitan area lighting system? Enough light to make out an object (no details, just an object) at 1000 feet sound about right? Be careful how you answer cause I am giving you rope to hang yourself.MSEE, PEComment
