Hello,
I'm new to these forums and indeed this is my first post as well.
I live in Copenhagen, in Denmark, in Europe.
The weather here is relatively cloudy and with temperatures mostly around 20o Celcius in summer and down to -10o C in winter.
Generally solar panels are not used much here, due to the weather being as it is.
I have not worked with solar panels before, but have had an interest in the area for years. I am pretty much starting from scratch when it comes to practical implementation, but lets see.
My hopes is that this can eventually become a prototype that I can build or put together. It would be fun to see if it will work or if it becomes too expensive to produce compared to just more plain panels. I also worry about maintenance, it must be sturdy and relatively self-contained.
Here is my idea. Please feel free to comment and point out flaws:
A dish construction with a centrally mounted arm. This placed on a structure that can pivot to make the dish face the sun.
The inside of the dish would be lined with reflective material.
At the end of the arm of the dish, there would be placed a solar panel pointing inwards, towards the mirrors. It would ideally be circular.
I'd like to break up the construction in each of the elements as each of them have their own challenges:
A. The solar tracking pivot mount.
B. The reflective dish.
C. The solar panel.
D. The central arm.
Chapter A - The pivot mount
A.1. The Mount
- The mount will be determined pretty much by the size and scale of the dish and panel.
A.2. Tracking the sun:
- How is this done best? - Is there a piece of equipment you can get off the shelf for this sort of thing?
Chapter B - The reflective dish
B.1. The physical dish
- Do reflective dishes exist already? - If I have to find a way to order one, do you have any leads to where?
B.2. Reflective surface
- The coating has to be reflective enough to get the job done, yet not too reflective as that will simply heat up the panel to a degree where any material will melt. Ideas?
B.3. Secondary input
- Is there a way to harness the excess energy that will be absorbed in the dish material?
- Placing a coil of water pipes on the shadow side for a water cooling system for the central solar panel? (Running along the arm to the panel's backside.)
B.4. Keeping it shiny
- It rains quite a bit here. Making sure the water can run off the dish in the middle and that nighttime parking position allows water to run off and avoids bird droppings.
- Is the weak light reflected from the moon and over the horizon strong enough to be collected at night? - We are so far north that really dark night is not something that happens unless it is also cloudy. (Which of course it is...)
Chapter C - The solar panel
C.1. Panel
What kind of panel should I look for to do this? - The mounting will get very hot. I need a sturdy panel that can handle it. A circular overall shape would be easier to target for the dish.
C.2. Cooling
- Some kind of cooling device could be hooked up, using the excess heat to evaporate water to cool down the panel? - I recall some tricks from my days as a scout, we'd make a basic refrigerator with dark plastic and water. Could that be adapted and used?
C.3. Piping
- Running a pipe with a water circulation system should be possible with the amount of heat there is going to be around. Using the warm water's evaporation to power the cooling and circulation. Anyone with hands on ideas for this? - My only frame of reference is PC cooling systems for overclocking.
Chapter D. The central arm
D.1. Placement and shadow
- I figured placing the arm in the center would minimize it's shadow as the dish will always be aiming at the sun. Correct?
D.2. Wires
I need to read up on the type of cable needed for the specific installation, do you know any good sources for that? - Cable durability; from both the environment and capacity from the wattage.
D.3. Pipes for the water system
- Maybe the water pipe can double as the structural carrier of the arm?
C. The solar panel.
D. The central arm.
A.1. The Mount
C.1. Panel
C.2. Cooling
C.3. Piping
D.2. Wires
