I Can't See How Leasing Doesn't Beat Purchasing, Can You?
What monthly payments?!!! I have none to make. Nada. Zilch. Zero. Not a penny. One up front payment of about a buck a watt. That's it. In exchange for 20 years of electricity production.Comment
Lease vs Purchase
Lets use something other than mystery solar panels. Like a car lease. You select a car. You pay monthly - about the same as purchase payments. You have mileage penalties, scratch & dent... all sorts of "conditions". At the end, you walk away, and have nothing, except you had 3 years in a fancy ride. Lease company sells the car and makes more $$ If you did a purchase, you have a car YOU can sell or do whatever with, or drive another 3 years w/ no payments. Maybe a lease works ok for a business expense, but for a ordinary person, it's just money that's gone with nothing in the end.
And I'm not a salesman, so I can't spin it as well as they do.
You do realize that quite a few of these leases have 100% buyouts after 6-7 years, right? I've seen quotes that allow for a buyout of $2000 on a system that cost $10,000 prepaid, and to have purchased that system, you would have paid in the neighborhood of $17,000 after all rebates/incentives. 7 years down the road, both people will own their respective systems except one will have paid $5000 more for the privilege.Comment
Your monthly's are based on your PG-E roll back credits, that's considered a PAYMENT. essentially that is your money its just liquid. what are you paying PG-E on avg.?
Or are you telling me you are buying out your lease early. Because really what you are telling me isn't making 100% sense.Comment
Except that solar panels are not like cars. Solar panels produce something that either the individual can use to offset electricity he or she would otherwise have to buy from the utility or in the case of net metering actually sell back to the utility if excess is produced. And that applies if you purchase a system or lease it. If at the end of 20 years, you don't own the solar PV system who cares as long as you've had the monetary benefit of it? Yes, there will be a residual value of the solar system. The question is what will be the value after 20 years of the difference between the initial out of pocket initial investment in a prepaid lease versus an outright purchase? In my case I'm looking at about $7500 less out of pocket by going prepaid lease vs purchase. In 20 years at 5% annual return, it'll be worth nearly $20,000. That's bound to be enough to purchase a new state of the art system with warranty, improved efficiency, etc., etc. And with the Sunpower lease, I can purchase it after year 6 and still be some $6,500 ahead than if I had purchased it initially.Lease vs Purchase
And I'm not a salesman, so I can't spin it as well as they do.Comment
So you bought it out to avoid the annual/monthly interest. They are going to handle all servicing for 20 years.
Sounds like that would be almost a deal even with 30% tacked on for labor and material, only because contractor has to maintain the system for 20+ years. Personally understanding the costs associated in solar I wouldn't pay that though. It is however deserving of a mark up. Just make sure you read your states guidelines on the statute of limitations. Even if it is in writing a contractor can back out of an agreement after 10 years, typically manufacturers can too. Its important to read up on your states laws.
Other than that you pay a little extra but you get servicing. Just as long as you avoid the interest payments you will do fine.
I don't get why you would just purchase up front rather than the lease agreement and save 30% on labor and material and still hold the contractor accountable for atleast 10years of warranty service as statute of limitations calls out for. That is essentially the best deal for you and you are protected as a consumer under your state laws and guidlines, and there is no charge for that.
If you purchase the system, contractor installs, it may not be the best deal as you cannot come after the contractor for warranty, you are accountable,unless you can prove negligence upon install.
If you allow the contractor to mark up accordingly for time and material at 10% the contractor becomes accountable for system up to 10 years, but only has to follow the minimum guidelines the manufacturer suggests. which is the way it should be. this is the biggest bang for your dollar as far as accountability is between contractor,installation, warranty.
If you lease, the contractor builds the system takes 30%, then bank charges you interest, "unless you buy out early in your case". Since the amount is above 10% a contractor must have a sales license for that state to charge 30% on top of labor and material. There will be contingencies in place that back up warranty past the 10 year statute of limitations, even with those clauses and contingencies however 30% may be a greater risk in payment as tehre is no such thing as 100% guarantee.Comment
I'm also looking at a prepaid solar lease from Sungevity. I have a quote for a 5.64kwH (STC) / 4.91kwh (CEC) system using 24 Sharp 235 watt panels. If I prepay the 15 year lease the system is $14,502 and this would have no monthly lease (as it's prepaid) but still include the full warranty, inverter replacement, maintenance and insurance. Our electricity use is almost always between 1100-1200kwh/month, and we are on the PGE E1 rate plan. This tiered plan has rates of 330kwh @ $.12233 for tier 1, 99kwh @ $.13907 for tier 2, 231kwh @ $.3018 for tier 3 and all additional kwh are @ $.3418.
I figured to get the optimal system size I want to get my tier 1 and tier 2 electricty (which are the 2 low cost tiers) from PG&E, so this is 429kwH. Since we use 1100-1200kwh/mo that means I need to get the remaining 671-771 kwH from the solar system. I used the data from the article below (see link) on page 2 he shows his actual monthly kwh from his 6.1Kwh system (his system in also in Northern CA relatively close to where I live). For all but Oct/Nov/Dec/Jan/Feb his system produced more than 754 kwh, so I figured for the peak months my system would easily cover the 671-771kwH needed. This is a monthly savings of ~$220-$250, and I'm guessing a savings of ~$100/mo for the winter months for an annual savings of ~$2000-$2250. Thus a basic payback of around 6-7 years assuming no increase in rates.
http://www.extremetech.com/extreme/8...one-year-later
Based on this thread I am also going to get a quote from Sunpower, but do these assumptions and calculations look correct?
jcgComment
AND THE LIGHT BULB GOES ON!!!
I almost fell from my chair. And I have a lot of patience for people who fail to understand things.
OMFG VINNIE! Ive been telling you this loudly in many many of my replies directed right at you.
You have finally starting reading the posts.
We don't make any monthly payments, we OWN the system with Early Buy Out after 6 years. There are NO power purchase agreements. None of that. I sound like a dang broken record trying to explain this to you.
You are talking about DIFFERENT leases than we are reviewing. Those are "old style" leases. They are craptastic.Comment
So let's start over,
Hi Vinnie. Nice to meet you.
I was wondering, since you repeatedly said leases are never worth anyone's consideration-- always buy. If I definitely want Sunpower equipment and willing to pay the extra for the brand since I have limited roof space & like their panels, what do you think of these two options:
Sunpower 6.8kw DC system in Central CA.
Choice 1: $38,000 up-front and I OWN the system on Day1.
I wait for $12k in tax breaks & rebates = $26k NET : $3.82/DC watt
Choice 2: $19,400 up-front and $600 at Year 6 Early Buy out with pre-paid lease: $2.94/DC Watt.
I OWN the system after 6 years.
No tax rebates or incentives, but I don't have to wait for them either.
I own all the power generated under the lease and participate in net-metering. I make no monthly payments. As of the 7th year, I would own the system no matter which choice I select. There was NO markup based on choosing the lease -- that lease was offered separately 2 months later as an alternate financing method if I chose to. Both systems have 10yr warranty and all the options are the same.
What's your opinion?Comment
JCG move this into a new thread and you'll get plenty of replies not entwined into the prior stuff. www.gosolarcalifornia.com has a great CleanPowerEstimate tool & pvwatts. The first one is a cool tool that allows you to get payback, ROI, estimated usage, AC CEC Rating etc all taking into account PG&E tier structure: plug in specific panels & inverters & your location. You know better than I, but "living close by" in Northern CA is often not comparable with respect to sunlight availability -- not a problem here on the valley floor where I am. But if you're looking for ballpark, you can compare from a neighbor assuming you have no shading issues. You'll get variance based on panel & inverter method. But I don't even have my system installed yet, just going off numbers from several different govt. sites and comparing them to installer quotes. Those kwh generation numbers are higher than the calculators & installer quotes will promise you, but my friends & installers always say they overproduce more than those calc's generate (at least in the first handful of years) maybe you better go with the conservative numbers if you're looking at long-term production tho.I'm also looking at a prepaid solar lease from Sungevity. I have a quote for a 5.64kwH (STC) / 4.91kwh (CEC) system using 24 Sharp 235 watt panels. If I prepay the 15 year lease the system is $14,502 and this would have no monthly lease (as it's prepaid) but still include the full warranty, inverter replacement, maintenance and insurance. Our electricity use is almost always between 1100-1200kwh/month, and we are on the PGE E1 rate plan. This tiered plan has rates of 330kwh @ $.12233 for tier 1, 99kwh @ $.13907 for tier 2, 231kwh @ $.3018 for tier 3 and all additional kwh are @ $.3418.
jcgComment
If that is the only rate plan available, then your calculation looks about right to me. We have a tiered rate in Arizona too but also a Time of Use rate plan which, after I did a calculation, wound up saving me even more money. Essentially, I bank on-peak kWh for the first five months of the year and never look back even during the height of the desert summer heat. I wind up paying little or no on-peak rates for the entire year.I'm also looking at a prepaid solar lease from Sungevity. I have a quote for a 5.64kwH (STC) / 4.91kwh (CEC) system using 24 Sharp 235 watt panels. If I prepay the 15 year lease the system is $14,502 and this would have no monthly lease (as it's prepaid) but still include the full warranty, inverter replacement, maintenance and insurance. Our electricity use is almost always between 1100-1200kwh/month, and we are on the PGE E1 rate plan. This tiered plan has rates of 330kwh @ $.12233 for tier 1, 99kwh @ $.13907 for tier 2, 231kwh @ $.3018 for tier 3 and all additional kwh are @ $.3418.
jcgComment
