NO No, it isn't See you are doing STRING level MPPT NOT module level MPPT. SolarEdge does Module level MPPT thus every module is operating at its MPP, not the combined string MPP..
Except Tigo doesn't do Module level MPPT and string MPPT doesn't match module MPPT when there are shadows and shadows tend to move around..
modules tend to have only ONE MPP with a few others that are close but by definition there can be only ONE Maximum Power Point. Further a string with multiple shadows is going to have a MPP but that will not be the same as every PV module in the strings MPP.
What system is NOT using MPPT at string or module? Why do you think string level MPPT is better than module level for shadows?
It seems that you can't get your head out of the string marketting BS. If there are shadows then there will be more power with optimizers than with a string system, you must be the only person claiming that strings can keep up with optimized systems in shadow conditions.
see here is a good example, all one string two modules have shadow from chimney at the instant:
Two PV modules have MPP of 25.88V while two near by have MPP of 31.38V and 31.63V (higher V are in shadow)
The two not in shadow are producing 8.07a and 8.14a while the two IN shadow are producing just 2.09a and 3.03
The two in shadow would not be able to keep up at string level MPPT but with module level they are putting out 66w and 95w still.
