I found the fine print about the feed in tariff program.
From that page,
>>"Small-scale installations up to 10 kilowatts (kW) will receive 46.8 cents per kWh."
Sounds pretty good, considering how much less a kWh currently is. Also, program rates can change but they won't change for the 15 year term that you sign up for to do this program. This protects from if they decide the program is too lucrative and decide to change it, but it doesn't help you if energy cost increases exceed your initial expectation that you based your decision to take join this program (which is a 15 year agreement). Considering this, the lower that utility rates remain the same over the next 15 years the more this program makes sense (due to the cost of the rate you sell your power having a greater difference between what it costs you to consumer it). Likewise, if rates went up significantly the more this is not as attractive as compared to the normal net metering arrangement. Correct?
something else I noticed...
>>"PGE is requiring customers installing systems under this program to have $1 million in liability insurance. This is beyond standard homeowners insurance"
I'm not living / insuring a million dollar home and wonder what the difference in insurance will run over the course of time.
					From that page,
