I have a 80 gal Ruud (solar servant) about 3 yrs old. I found a very old 4x8 collector and pump.
With advise from a contractor who sold me new thermal release valve and air purge fitting, I set up the system myself. All seem to be working fine with the diff controller I got from a put together kit.
It was last year when I notice the pump would run a little at night in cool weather. I then put a timer on pump to only allow it to run during the day time. I opened the cover on the check valve and cleaned off the build up with some vinegar. Lately I have not had enough hot water in the evening if I turn the breaker off. I occasionally turn the breaker off in order to see if solar is making enough on its own. The collector is on the roof directly above the tank. There is very little piping between the two. Last evening I checked the temperature on the roof with inferred. On the air bleed fitting that does not have any insulation, I was getting 89° compared to 60° from the metal racking nearby.
I realize this is not the most robust system but it was saving me power. My biggest concern now is if I leave the breaker on all the time, will I be losing more power then I was saving before this started happening?
