Hi All
I'm new to this forum and to solar technology. We have just had a pellet biomass boiler system installed feeding both our water and rads which is 'complemented' by 20 Joule evacuated tubes on the roof. The issue is this. We have been monitoring the controller which reports the temperatures on the roof (presumably at the manifold) , the top of the thermal store, and the bottom of the thermal store. We live in the south of England on the coast and yesterday was a mostly cloudless day with bright sunshine and a temperature of about 14 degs. When the solar cut in at about 10:00am the temps were as follows:
Roof 59.3
Top of thermal store 56.7
Bottom of thermal store 49.5
The temp curve then proceeded as follows over a period of 4 hrs between 10:50am and 2:50pm
Roof 59.0 55.8 56.4 55.3 61.8 56.4 46.9 50.7
Top of thermal store 56.2 54.8 53.4 52.5 51.3 50.8 49.5 49.1
Bottom of thermal store 50 48.8 47.6 46.8 46.1 46.1 44.4 43.5
Now during this time the solar was the only thing running, i.e. no pellet boiler, correct me if i'm wrong but I was kind of hoping that the temp in the tank would have gone up not down, or am I expecting too much in that period of time at that outside temp. By the way, the pump is set to cut in as and when it's needed, which it does. Any help would be appreciated before I sign this job off, which i'm not inclined to do as you can imagine.
Roof 59.3
