Russ's suggestion prompts another possible cause for my failures.
If I had a poor solder seal, however small the leak, the cycling of pressures night to day would vent acetone and suck air until stoic conditions were met.
Since they didn't fail immediately upon installation this may be an equally likely scenario.
I'm torn on the hottest part of the heat tube.
On one hand, I thought the amount of copper wrap around the heat tube may have prevented cooling air from circulating, creating a more then others sealed oven at the bottom of the evac tube. Maybe.
On the other hand, the acetone should boil off from the bottom transferring heat to the top. (Where manifold would take it away if installed, air since it wasn't)
On the third hand, acetone will only boil until heat tube pressure tells it to stop, then the fluid will rise in temp. No air, no autoignition.
On the fourth hand, I may have had a poor solder seal - leak, suck, stoic, flashover igniting tube gas leakage.
On the tail, there was ignition, so regardless of failure mode, evac heat tubes can reach acetone autoignition temps.
One tube did not launch but blew out copper wrap. So - autoignition of the gas mix in the evac tube.
Since the other launched with relatively high energy, it likely dieseled once it reached stoic (inside heat tube) and sufficient pressure due to temp.
Any way you view it, 2 out of 35 is not a bad failure rate for a newby solderer/acetone air evacuator.
I did think about how to test these heat tubes after build, but couldn't come up with a practical test to ensure they were sealed.
8ccs of acetone might be difficult to differentiate in weight from extra solder, or variations in tube length regarding a weight test.
