[QUOTE=russ;27212]From your wikipedia article - [I]The vast majority of heat pipes for low temperature applications use some combination of ammonia (213
Bad experience with evacuated tubes.
Agreed but that is not simply welding.
It would be interesting to know more about heat pipes - solutions, degree of vacuum etc but it is difficult to find - at least what I have read from various manufacturers hasn't said much.Last edited by russ; 07-14-2011, 03:18 PM.[SIGPIC][/SIGPIC]Comment
I would hope I know a little about this as I also do this for a living (Sales now installs way back.
And where did the heat pipes in fridges come from I never mentioned low temp ones.NABCEP certified Technical Sales Professional
Don't do service and mostly flat plate thermal (Sorry) but I will run this by the Service Dept.NABCEP certified Technical Sales Professional
Under warranty
RJ Randall,
Your Apricus collectors are still very much within their warranty period. Please contact me personally or our main office to discuss your issues and ensure that you get the appropriate replacement parts to get your system up and running properly. We're not happy until you're happy.Comment
This is how I made my heat tubes:
In the absence of timed heating machines for ensuring vapor evacuation of air and perfect seal when soldered, it is indeed an art form.
I didn't use the plumbing riser bit, just an end cap with a center punch dot in the middle to trigger the condensate return to liquid.
I soldered rather then brazed. Sufficient melting temp buffer there anyway.
Acetone works great and it's volatility ensures a rapid gas/liquid heat exchange.
Because they're isolated mechanically from the collection loop, there is no danger of potable (should one choose to use it) contamination.
The biggest difficulty is timing the solder application and heat removal to get an effective solder seal whilst acetone tube pressure swings by zero bar.
Cooling does the vaccuum for you afterwards.
Why a manufacturer would use water eludes me. Regulations perhaps.Comment
Very cool. Do you have a blog or web site covering collectors and building them?This is how I made my heat tubes:
I've heard of using propane as a replacement working fluid in air conditioners, as long as we're talking about "out of the box" thermal fluids.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The fellow in the video is merely my inspiration for using acetone as transfer medium.
I am a humble self educating newb working toward some less processed energy for heating and perhaps TEG generation next summer.
Like many here, it's something I must do.Comment
Chinese heat pipes use water and Cu powder
Water is safer, cheaper and transports the most energy per gram of just about any fluid.This is how I made my heat tubes:
Freezing is an issue that is being solved by using very little water, and they add a coarse copper powder to the water. I haven't really found the official reason for the powder. But it apparently causes the to water to freeze in the tip before making an ice plug. If it freezes bottom first and expands upward, no damage will occur.Comment
heat pipe siezing in header
GRRRR, My manifold has cracked somewhere and to fix it i attempted to remove my tubes from the header assembly. The glass slips out just fine but the heat pipe is stuck in the manifold!! I have already broken one heat pipe trying to remove it. Please can anyone help me. It does look green up in there and i cant even remove the bulb nwith much force from the one i already broke!! Help me please. I have it covered so it will cool off and i hope it will disengage when it does.Comment
Safer for installation, transport and install agreed. For troublefree use in Northern climates, not so much as is evident by known failures.Water is safer, cheaper and transports the most energy per gram of just about any fluid.
Perhaps the copper powder is intended to manage crystal formation and diffuse lateral pressures at the bottom of a heat tube? As long as the amount of water covers the bottom of the capped end, there remains risk of a split in the event of freezing. While I agree that water would be preferred for heat transfer, it's properties alone also add risk to freeze failure. I'd love to read some reasoning for copper powder additive if someone can speak to it directly. For now I'm sticking with Acetone, but reserve the right to flip my opinion if sufficiently informed otherwise.
I'm not sure how copper powder would cause freezing to occur in the tip first (If by tip, you mean upper manifold end?).
If it freezes bottom first, damage may very likely occur. Why do you say it wouldn't?
In a failed evac tube freezing might occur anywhere in the water based heat pipe, but in a good tube exposure to temps is limited to those areas exposed to weather or poorly insulated from it (grommets, flashings etc). They're not perfect insulators, but they're not perfect vacuum either. The chances of Acetone freezing are well past -78C directly exposed. We see -35C on occasion here, so water = bad in my part of the world. Your mileage will vary.Comment
freezing and water heat pipes
Heat pipes use very little fluid. About 2-4 ml of water, acetone or whatever.
The mechanics of pipe damage due to water freezing are as follows:
1. Water in the bottom of a mostly empty tube tends to freeze from the top of the water down. That's because the coldest water becomes buoyant at 39F and rises up to freeze (that's why we can skate on partially frozen lakes)
2. The freeze plug that forms on the top surface of the water sticks hard to the sides of the pipe.
3. As the freeze plug expands downward, it pushes on the incompressible liquid water, which splits the pipe.
So, if you can coax the water into freezing at the bottom tip of the tube first, and expanding upward, there is no split.
The Chinese solution is: a small amount of water mixed with a coarse copper powder.
As I say, I haven't seen any documentation on this. I just tore apart a few heat pipes to see what was inside. I also put them in a freezer to see if the tip diameter increased when frozen. It didn't.
Don't get me wrong, I'm not against acetone, I'm just reporting what is in millions of Chinese heat pipes (SunRain)Comment
Your Manifold Cracked Because it Froze
When the manifold (header) freezes, it clamps down hard on the heat pipes. I know this because it happened to me. But luckily, my header didn't split, so the collector still works fine.GRRRR, My manifold has cracked somewhere and to fix it i attempted to remove my tubes from the header assembly. The glass slips out just fine but the heat pipe is stuck in the manifold!! I have already broken one heat pipe trying to remove it. Please can anyone help me. It does look green up in there and i cant even remove the bulb nwith much force from the one i already broke!! Help me please. I have it covered so it will cool off and i hope it will disengage when it does.
So, don't worry about getting the heat pipes out. Remove the header insulation and maybe you can find and braze the split closed. Solder won't hold.Comment
Removing cover on header
anybody ever remove the cover on the manifold? It has two plastic end caps that are riveted on. Is this even possible with the tubes attached? Dont trust the built in freeze protection on the controller. Trust glycol! Thanks Art.The manifold will work fine in the summer at 15 psi so i hope the crack isnt too bad. gonna start poppin rivets.Comment
Query for Art:
How much copper was included in the mixture?
That is, would it be sufficient in quantity to allow the volume of water to be below the powder in the tube?
Curious now...Comment
