I'm a noob. please forgive my dumb questions. I am going to use evacuated tubes to heat water in a hot tub (electric backup). I'm planning a closed loop with glycol (we live in a freezing climate). Is there any reason NOT to think of the hot tub as a hot water storage tank? Can I just install a copper coil for a heat exchanger in the hot tub, under the seats?
All the info I can find suggests using a closed loop with a heat exchanger and another loop for the tub itself. It seems to me to be unnecessarily complex and expensive (exchanger, pump, plumbing) when I could just run the coil in the tub.
Thanks, Dennisg
Thanks, Dennisg
