I got a handle on it. I have a 2 gallon container under the hi-lo controller and in the container I placed a 400gph pond pump set up on a digital timer. Every six hours the pump cycles for one minute. The leaking water is pumped into a 30 gallon tub a few feet away which is fastened to a hand truck, When the tub is full I wheel it out side and dump it in our front yard or rose beds. This is working for now and not so panicked. I knew nothing about this system a month ago. I really need a referral to an outfit that can replace my tank way out here in Idaho. Going to try heated flooring companies next.
Solar tank leak is bad but
