Announcement
No announcement yet.
Is this normal? Does my system need tweaking?
  • Filter
  • Is this normal? Does my system need tweaking?
    COLLECTER TEMP: 68.8 Degrees Celcius
    BOTTOM OF STORAGE TANK TEMP: 53.3 Degrees C
    TOP OF STORAGE TANK TEMP: 53.8
    The pump is working at 95% Speed.
    Should the storage tank be at a higher temperature or is this normal?
    Apologies for the extra thumbnail in this thread. Im not sure how that got there.
  • #2
    [ATTACH=CONFIG]4888[/ATTACH][ATTACH=CONFIG]4889[/ATTACH][ATTACH=CONFIG]4890[/ATTACH][ATTACH=CONFIG]4891[/ATTACH]
    Hard to say. I'd check all the thermometer connections first. What's the flowrate ?
    • #3
      How can I check the flowrate?
      • #4
        There should be a flow meter in the control section - a rotameter probably
        • #5
          Further to this A.M.:
          1.) How old is the system ?
          2.) Have you contacted the installer ? Good installers are usually anxious to help. Info given here so far makes only guessing possible.
          3.) I have Pentair flowmeters in my system. They've worked fine & trouble free for 6+years. try P/N LDF357B. P/N will be slightly diff. for different flow capacities and connections. I got sweated end version. I'd avoid nylon threaded version. Also, CAUTION: Do NOT use in direct sunlight. Price is about $85- $90 U.S., depending on source.
