Hi to all,
I would like to ask a Q regarding the position of the hot water storage tank which is placed above the flat panels.
I noticed that the houses that use vertical tanks have hot water faster and manage to keep it hot even after cold water is going through because of use...when the horizontal ones seem to lose their energy faster and require more time to get the water at the same temp(obviously it will have more volume of hot water but can't be used if it only reaches 25C(77F).
I know it's simple physics but the manufacturers here insist that there is no difference.
I also would like to ask in the case i use a horizontal tank just because my wife doesn't want it to be seen at the roof!! Is there a difference whether the inlet piping of the hot water from the panels gets in the tank in the middle or at the top?
I've seen a few on the internet where the exit of the tank for the DHW was coming from the same pipe where the inlet from the panels was.
Middle inlet
Top inlet
.I also would like to ask in the case i use a horizontal tank just because my wife doesn't want it to be seen at the roof!! Is there a difference whether the inlet piping of the hot water from the panels gets in the tank in the middle or at the top?
Middle inlet
Top inlet
