Hi one and all
I have installed a 60 (2 x 30 tube) tube system heating approx 400Ltr HW cylinder.
I pressure the system and it seemed to hold the pressure over night, then filled the system prior to adding the tubes, several months on I seem to be seeing a drip coming out the lower end of the header, I am not convinced it is leaking as it held the pressure during the air pressure test, and the system pressure doesn’t seem to be dropping. I wonder if it could be condensation. The system pressure has never been above the 2.5 to 3Bar running pressure (never dumped any liquid dumped into the overflow tank). And the temperature of the panels has never been above 95 to 100°C there is a heat dump that brings the panel temperature down to approx (a little dependant on ambient temperature) 40 to 50°C.
My main question is could the header be leaking? Have people come across this before? How is the best way to find the leak, decommission the panel (remove the glass), drain the system down, re-connect the pipe work to the other panel, refill the system, and bleed? Remove the header from its casing, look for signs of the leak, pressure test with air or water depending on if the leak can be spotted?
I assume they are only silver soldered?? I have access to this……
Sorry for all the questions.
Best wishes to all,
Michael
Best wishes to all,
Michael
