why is my water yellow
As Naptown pointed out - water softeners are a common thing - no reason to pay for a fancy name.
Do your research and scratch off the names trying to make something special of them. Salesmen making home calls are the worst of the lot.
There is a great amount of information available on the net - manufacturers sites and forums. Forget youtube![SIGPIC][/SIGPIC]Comment
Actually, a water softener removes calcium ions from the water and replaces them with sodium ions. It will not necessarily do anything for dissolved iron.As Naptown pointed out - water softeners are a common thing - no reason to pay for a fancy name.
Specialized iron removal filters may well cost more than simple water softeners and may require periodic cartridge replacement rather than regeneration in place.
Not to say that some ordinary water softeners are not promoted for iron removal, so be careful.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Funny
I lived on a well with huge amounts of iron to the point I had dual softeners and PH correction and never bad yellow water other than when I let the salt run out.NABCEP certified Technical Sales Professional
YMMV, depending on the exact nature of the iron content of the water.
At our house in Illinois the well water (80') had a high enough iron content that even with a filter followed by a water softener only on the hot water line the dishwasher turned rust colored very quickly. The water did not look yellow, but you could smell and taste the iron.
Take a look at this resource: http://www.hillwater.com/resources/iron-removal.aspx
The biggest problems I know of are thatOn some iron waters, it is immediately clear that a softener should not be used. Dissolved organic-iron compounds may simply pass through a softener, unaffected by either ion exchange or the filtering action of the softener bed. Solid organic matter particles frequently contain quantities of precipitated iron, and the combined solids can lead to rapid fouling of the bed. Iron bacteria in water can rapidly foul softener beds, and worse, can grow and pass through the beds in slugs. When such materials are found in the water, softeners should not be applied.
1. if you have iron-organic compounds ion-exchange cannot remove it.
2. some designs of softener ion-exchange resin beds are permanently damaged by iron or fill up on iron between regeneration cycles (even daily) and let iron through.
3. You can have iron bacteria in the well itself, which requires a different removal approach.
The alternate approaches include simple filtration for precipitated iron and a different kind of catalyst bed than the ones used in a conventional softener which causes the soluble iron to precipitate and get filtered out instead.
Once again, I am not making any claims about what exactly the originally advertised iron removal systems actually do.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
I don't know if it's true, but the sales pitch for the ozone generator I use ( tripleo com/impuriti.htm - put the dot in if you copy and paste it) claims the ozone & bulk filter will clean up :
Metals, iron and manganese, which can stain laundry and bathroom fixtures as well as lending unpleasant taste and odor to water, can be removed though oxidation and filtration.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
That part is a valid generalization. And the ozone is likely to break down any organic iron compounds as well as changing the oxidation state of ionic iron compounds.
Looking at the filter can give you a good idea whether it is working.
I didn't mention specifically treating for iron - that one has to learn about the entire scenario.
There are the softeners and filters for about everything.
Top of the line is reverse osmosis though then you need to insure you have adequate intake of trace elements.
If one buys Rain Soft they need to realize they are paying maybe 50% for equipment and 50% for name.
The sales people that come to your house and take a sample normally trash the sample as soon as they go around the corner - the answer is, "Yes you do need what I am selling".[SIGPIC][/SIGPIC]Comment
