Would like to find an automatic shutoff for 50 gal electric hot water heater when my 5 ton heat pump comes on.
The watts get too high for a 8,000k backup generator. The backup generator has 10,000k peak watts. The graph shows hot water heater coming on in blue over red (red is everything running in my house).
The volts are at top in red.
You can see hot water heater coming on again around 3:00 PM.
Before 9:00AM, you can see the heat pump comes on without the hot water several times. 6,000k is ok for the generator. But for some reason the hot water heater likes to come on when the Heat pump is running. My water heater has a circuit board on the top of it. There's leds on which element has burnt out. and other switches.
See the peak at about 9:45 AM this morning. 11,500k not good for generator.
This is a Ted 5000 system running.
