Hello All.  New member from Southern Calif.  Wondering if any of you solar experts have run across this problem?  Any advice would be appreciated.
I've been a pool owner for 12 years and heat the pool with a roof mounted solar panel system. Recently, after the pump has been turned on for about 15 minutes water starts to come out of the roof mounted air vent leaking off the roof. The air vent is designed to allow air back into the system after the pump is turned off so water can drain back into the pool. Seems to me I have too much pressure in the system but I don't understand why since it's worked for years...I've made no changes to any of the equipment except one (I took one 4 x 8 panel out of service that left 13 remaining. This was done last summer). I changed the air vent and that temporarily solved the problem but 2 weeks later it started again.
Even more frustrating is that this happens even when the solar system is completely turned off meaning the diverter valve is set to send the water to the gas heater and by-pass the panels. Could this have anything to do with the diverter valve or other misc check valves? Any thoughts at all? I'm lost.
Thanks,
Bill
Thanks,
Bill
