How many degrees warmer do solar heaters get the water?
It depends on the panel type and the flow rate.
An evacuated tube collector could raise 80F degree water to 250F water pretty easily at a flow rate near zero, while a flat panel collector would be working pretty hard to get to 180F.
Because of the details of heat loss from the panel, the maximum temperature increase will not necessarily be independent of either the input water temperature or the ambient air temperature.
A pool heater with a high flow rate might only increase the water temperature by a few degrees, but the effect would add up as the pool temperature (inlet water to the panel) increased.SunnyBoy 3000 US, 18 BP Solar 175B panels. -
For reasonably well designed systems:
Pool heaters usually operate a few degrees above the pool water temp.
Well designed solar domestic water heaters will usually, on a sunny day, depending on a lot of variables, heat a tank of H2O something like 40 to 80 deg. F. per day above the cold water temp. Lots of variables make that a VERY approx. #.Comment
And over time those degrees add up.
Although the output water from the solar heater is only a few degrees warmer than the input, you can still get a significant temp difference compared to an unheated pool.
I pretty much only run the pool furnace when I want to heat up the hot tub (the hot tub and pool share equipment - the hot tub overflows into the pool.)
I'm removing panels though - going from 10 to 6 to make room for PV panels. So we'll see how I do this summer.Comment
Of course they do. that's how they are supposed to operate.And over time those degrees add up.
A gas pool heater can be rated at 120k btu per hour.
5-6 Solar panels could produce that much in a day of sunshine. But it's free energy!Comment
The solar energy is free. The best way to heat a pool from an economic standpoint probably includes solar energy collection equipment that is usually not free.not free.
A properly designed solar pool heating system can produce as much heat as needed over the course of a season or year round if that's the duty.
The point of design is to find the best way to meet the required duty - in this case a pool water temp. that is suitable.
Usually that's some combination of pool cover/solar collection equipment/backup heat source (that is usually fossil fuel fired) that best meets the user defined needs in the best combination (after safety) of tradeoffs between, most practical, least maintenance and most cost effective, again as defined by the owner/user.
To say that 5-6 panels may match the output of a 120MBTU gas fired heater is too loose a statement to put a lot of faith in.
Depending on location, time of year, etc. a common, decent solar pool heater might add 600-800 BTU/ft^2 of collector area to a pool on a warm, sunny, summer day. Less when the sun is lower in the sky, or a pt. cloudy day when it's cooler. The collector area is one of the design outputs.
Usually, a 1st cut is to have the collector area about half to 2/3 the size of the pool surface area, but that's not a substitute for a decent design attempt including all opportunities for heat retention/addition.Comment
The gas heater is per hour, the solar thermal per sunny day. I wasn't trying to Say that the capacity was the same.
I service a residential 125k btu pool water HX and boiler, it runs for approximately 6 hrs per day to maintain 80 degrees. They use a cover when not in use. I tried to sell them a thermal system but the $ vs savings does not work out because of the year round use and low sun hrs in winter.
I understand. Without busting on you, your customer or anyone, the situation you describe may be at least partially the result of the type of either/or dichotomous thinking that is often resorted to - either solar or fossil, not both. Some other thinking, such as can the fuel savings alone justify investing in a solar water heater in addition to a gas fired heater ?Comment
Live in Ontario.
Have a concrete pool 16'x32'x8' single depth.
Have 12'x24' of solar thermal panels fed from the pool filter pump.
Easily raise entire pool temperature 2F every day in the summer months.
Pool pump is run from 10AM to 4PM daily. The outlet temperature is typically 5F warmer than inlet.
By second week of June, pool is 84F and stays roughly that till first week of September.
Total cost under $3000 more than 10 years ago.
Little to no maintenance, fixed a leak a few years ago.
Panels look like this :
maintain-pool-solar-panels-800x800.jpgComment
Our pools ate closer in size & location. My gas heater was able to heat the pool 2-3 degrees per hour back in December when water was 55-60 degrees. I don't know what it cost to run the gas heater since I only ran it a couple of times back in December when I also ran the central great in the house - I've only been in the house a year.Live in Ontario.
[ATTACH=CONFIG]6372[/ATTACH]
After a PV system is installed I may look into an electric pool heater.
What cost more, a few hours of running a pool pump at a much higher speed (I have a variable) or running a gas heater fir an hour or two a couple of times a month?Comment
I'm not at all sure what your hydro costs are in Ontario, but I'd be very surprised if providing heat to a pool using electricity, even via a heat pump, could compete on a cost basis with CH4. Heating water with electricity is like cutting butter with a chain saw. Match the source to the task.Our pools ate closer in size & location. My gas heater was able to heat the pool 2-3 degrees per hour back in December when water was 55-60 degrees. I don't know what it cost to run the gas heater since I only ran it a couple of times back in December when I also ran the central great in the house - I've only been in the house a year.
I have 8x8 2x500' 1/2" black irrigation tubing.
I have 8x8 2x500' 1/2" black irrigation tubing. Water going in typically is 70'. Output is 78' normally, not always, and after it's been running a short time. Intial output is around 150'. The pump is a small 5 gpm type. The pool has 3,300 gallons. Over the course of daylight (my location is a rental property, I only get direct sunlight 5-6 hours), the pool will raise to 78', then cools off over night to repeat almost identically the next day. If I had the room, I'd do another 8x8' setup, thinking it would be a 16' raise over the same time period.
I had considered adding 1/2" 50' copper tubing. That 50' to me is free, anything after/over, I would have to pay for. Would it actually help? Or as some others suggest, use a pool cover...Comment
I would recommend reducing your coils to 180' to 220' maximum per panel. You are probably maxing out on thermal absorption and not picking up any more heat. Reducing each coil to about 200' and having about 4-5 coils in parallel should help increase your pool temp.I have 8x8 2x500' 1/2" black irrigation tubing. Water going in typically is 70'. Output is 78' normally, not always, and after it's been running a short time. Intial output is around 150'. The pump is a small 5 gpm type. The pool has 3,300 gallons. Over the course of daylight (my location is a rental property, I only get direct sunlight 5-6 hours), the pool will raise to 78', then cools off over night to repeat almost identically the next day. If I had the room, I'd do another 8x8' setup, thinking it would be a 16' raise over the same time period.
skeeterComment
It's really all about storing BTU's and not how hot the water from the heater is. If you slow the flow to get measurably warmer water out, you increase the thermal Delta, and increase the losses. If you only get .2 degrees warmer, there is much less loss, and the pool eventually warms up, not just the top layer.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
