I'd never suggest that the word ignorance has a necessarily pejorative context. I would suggest comparing commercial units one to another and forget, or disabuse yourself of the DIY hose business. That's B.S. for anything much more than small residential applications where cost effectiveness and safety are often on the back burner.
Before that, more suit yourself: invest 20 bucks on a book about solar energy that includes thermal applications. You will be in a much better position to see where I'm coming from.
Black plastic coiled collector questions
Those coils are a total ripoff - you need black plastic pipeLeave a comment:
I agree the commercial coils we have a as you said, one of the reasons I am recommending to the club we don't buy anymore and go with the less expensive option of making the black pipe we have more efficient.At the risk of being non P.C, my guess is your ignorance of the solar heating process is causing and will continue to cause confusion and cost you money if you continue along this line.
Do as you see fit, but those coils pictured are probably very inefficient, ineffective and from the price I saw, a rip off. Avoiding solar all together is more cost effective than those contraptions.
Check out flat plate pool heating panels such as those from a co. called Fafco or others. Usually, to be effective, a solar pool heater needs to have an area something like 1/2 to 2/3 of the pool surface to be effective. Don't shoot me, I'm only the messenger with an opinion.
Your use of the term ignorance is well placed in this case, I only know what I have read so far and the basic principal behind solar heating. I am going for something like http://rimstar.org/renewnrg/solar_po...ter_diy_fp.htm but on a smaller scale for now, adding coils as we get the money to do so.
Edit: I do however want to compare the commercial units we have with the finished black pipe system to see how much they heat the water passing through.Leave a comment:
At the risk of being non P.C, my guess is your ignorance of the solar heating process is causing and will continue to cause confusion and cost you money if you continue along this line.Commercial units? We do have 4 commercial collectors, similar to this. We also have an undetermined length of black pipe coiled and laying on the ground.
My desire is to make the black pipe we have coiled and laying on the dirt more efficient so we don't have to use our gas heater as much. This club is not a money making machine so money to buy more of the commercial collectors is tight. With some donated materials I can make the black pipe more efficient without spending much of anything.
Check out flat plate pool heating panels such as those from a co. called Fafco or others. Usually, to be effective, a solar pool heater needs to have an area something like 1/2 to 2/3 of the pool surface to be effective. Don't shoot me, I'm only the messenger with an opinion.Leave a comment:
[QUOTE=J
Better yet: Do it bright and get solar pool heating collectors. Better, more efficient, looks nicer, fewer problems.[/QUOTE]
My desire is to make the black pipe we have coiled and laying on the dirt more efficient so we don't have to use our gas heater as much. This club is not a money making machine so money to buy more of the commercial collectors is tight. With some donated materials I can make the black pipe more efficient without spending much of anything.Leave a comment:
The idea is to intercept as much solar energy as possible. A black coil 1" coil in , say a parallel pattern on 2" centers will cover half of a 4 X 8 sheet of plywood and have an effective area of 16 ft.^2. A "better" (denser) design will, for example have 1" centers - touching. On the 2" centers, unpainted reflective material will "bounce" solar energy to the back side of the tubing in a more efficient way than a flat black painted surface will reradiate infrared thermal radiation. That, and a lot more reasons make for my best educated opinion. A bit more detail would be necessary to confirm/refute/modify.J.P.M so you are saying the reflecting of the light from the reflective insulation will better transfer heat to the plastic coils? Wouldn't the light that you can see reflecting back into the atmosphere be wasted energy? I use this same type of reflective insulation in a large window in my house when I don't want the summer sun to heat that room up. in between the glass and the insulation it always really hot; on the room side of the insulation is always very cool. Shouldn't this be attributed to the reflective property of the insulation returning the light to outside of the house instead of allowing it to be absorbed? Wouldn't a coat of black paint allow the light to be absorbed and reflected back by the foil layer as radiant heat instead of simply light? Isn't that the whole technology behind this foil layered insulation, that it reflects radiant heat?
I am new to creating solar pool heaters and my intent is to gain some insight from people that have already accomplished this stuff. My intent is not to sound insolent so forgive me if I do.
Bottom line: Pack it tight and insulate behind the coils with durable reflective material on top of the insulation. Avoid stagnation as much as possible. Do not put a cover or any glazing material between the coils and sunlight.
Better yet: Do it right and get solar pool heating collectors. Better, more efficient, looks nicer, fewer problems.Leave a comment:
Sorry I did not include that part in my OP, I assumed that since this is the pool heater board it was understood.
More background:
Pool heater.
Existing gas and rudimentary solar heat.
Unknown pool capacity<-- Next meeting I will be gaining lots of information like this.
Unknown length of existing solar coils.Leave a comment:
J.P.M so you are saying the reflecting of the light from the reflective insulation will better transfer heat to the plastic coils? Wouldn't the light that you can see reflecting back into the atmosphere be wasted energy? I use this same type of reflective insulation in a large window in my house when I don't want the summer sun to heat that room up. in between the glass and the insulation it always really hot; on the room side of the insulation is always very cool. Shouldn't this be attributed to the reflective property of the insulation returning the light to outside of the house instead of allowing it to be absorbed? Wouldn't a coat of black paint allow the light to be absorbed and reflected back by the foil layer as radiant heat instead of simply light? Isn't that the whole technology behind this foil layered insulation, that it reflects radiant heat?not painting reflective material will probably result in more heat to the fluid at least partially because:
- The reflective material will absorb less solar energy and heat up less, resulting in less heat transfer to the support material (plywood ?) behind the reflective material. A heat balance will show such heat transfer will be lost out the back and unavailable for fluid heating.
- The short wave reflectivity of the unpainted reflective material will likely result in more of the reflected energy being absorbed by the plastic material than reradiated infrared energy being absorbed by the plastic material.
I am new to creating solar pool heaters and my intent is to gain some insight from people that have already accomplished this stuff. My intent is not to sound insolent so forgive me if I do.Leave a comment:
I'm assuming this is a pool heating application? I don't see where anyone specified/confirmed the application. Without more information I'd start out by saying if a pool heating application and plastic tubing coiled up, not painting reflective material will probably result in more heat to the fluid at least partially because:
- The short wave reflectivity of the unpainted reflective material will likely result in more of the reflected energy being absorbed by the plastic material than reradiated infrared energy being absorbed by the plastic material.Leave a comment:
The metal pipe is not really an upgrade - just use more plastic pipe - cheaperWith a light coat of flat black paint on the reflective insulation the black should absorb the light but reflect the infrared heat back towards the coil. I don't think reflecting the light would help any over only reflecting the infrared heat. Metal absorbers as in a metal coil or straight pipe? The club has existing black flex pipe in place, but it is randomly laid out on the dirt; I am trying to make what we have more efficient with as little added as possible.
I would love to upgrade to copper or stainless piping but that would need to be voted on by the board of directors.Leave a comment:
With a light coat of flat black paint on the reflective insulation the black should absorb the light but reflect the infrared heat back towards the coil. I don't think reflecting the light would help any over only reflecting the infrared heat. Metal absorbers as in a metal coil or straight pipe? The club has existing black flex pipe in place, but it is randomly laid out on the dirt; I am trying to make what we have more efficient with as little added as possible.You WANT the reflection, because part of it will warm the underside of the coils.
Reflectix is NOT UV rated - it will rot out in a year on the roof.
Commercial enclosed panels, use metal absorbers, and they will convect heat away, so they need the lid. The metal is much more effective at heat transfer from the hot outside, to the cold water inside. Have you considered SS tubing coiled up ?
Plastic is best used for low temperature applications like pool heating or preheating, probably not much more than 40 deg. C. or less.This makes me wonder why the commercial systems are almost always enclosed.
Do you know of anyone something like this to insulate between the coil and the plywood? Im thinking a think layer of black paint to cut the reflective properties of the foiled insulation.
If you are referring to "commercial " as in DHW or heating applications, that equipment is usually metallic in nature for a lot of reasons dealing with better durability relative to plastics, etc., particularly at elevated temps. and also for usually more efficient heat transfer characteristics.
Usually, for the applicable low temp. applications, the decrease in performance caused by a cover blocking some solar energy is usually greater than the increased loss by not having a cover.
Plastic for low temp. applications vs. metal for higher temp. applications is an example of appropriate technology for the appropriate application.
Add: +1 on durable reflective material behind the collector surface. And, skip the cover. You'll melt the plastic under no flow conditions/pump failure/etc.Leave a comment:
You WANT the reflection, because part of it will warm the underside of the coils.This makes me wonder why the commercial systems are almost always enclosed.
Commercial enclosed panels, use metal absorbers, and they will convect heat away, so they need the lid. The metal is much more effective at heat transfer from the hot outside, to the cold water inside. Have you considered SS tubing coiled up ?Leave a comment:
Do you know of anyone something like this to insulate between the coil and the plywood? Im thinking a think layer of black paint to cut the reflective properties of the foiled insulation.Leave a comment:
