hi there! I wonder if computer fans can pull hot air downwards? 3 meters (10ft).
Computer Fan to pump air Downwards?
That depends on the temperature difference between the hot air and the surrounding air. (For 500F it might be a stretch.)
But for a quick sanity check, feel the upward draft created by the unobstructed hot air and compare that to the pressure you get when you partially cover the computer fan with your hand.
It should work.SunnyBoy 3000 US, 18 BP Solar 175B panels. -
Computer fans last longer, the cooler they are. Removing them from the hot air stream will lengthen their life, as would using ball bearing fans, or hydro-wave-something fludic bearings.
Personally, I prefer to mount fans at the bottom, and blow cool air into the device to be cooled. When the hot air exit is at the top, natural convection assists the airflow, and can become the "primary" movement method, if designed right, leaving the fans to be secondary for extreme conditions, and prolonging their life.
There are pressure and airflow curves published by fan manufactures, but by the time it trickles down to the 3rd re-brander, you may not be able to get true answers.
MikePowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
