Announcement
No announcement yet.
Twist on Solar Heating
  • Filter
  • Twist on Solar Heating
    I have a 4 bedroom 2 story in Nebraska
    We have heating/cooling problems in South West upstairs- appears to be duct related, and would cost $$$$ to get to.
    Outside wall is standard siding, minimal insulation. Was originally looking at standard air heating panel, but running into technical issues; namely, windows are sideways sliders, not finding simple way to attach to windows.
    Came up with idea, don't know if sane/possible. What would happen in black material was attached directly to siding? (think blacked foil) This would not require windows, heat would go in same way it leaks out....
    Worth trying/stupid, ways to improve idea?
    Thanks for input
  • #2
    Unglazed won't do much if anything. Glazed as you are thinking could present a host of problems including the potential of fire.
    • #3
      1) Collection won't be that great with a black wall but it would a little better than a white wall - probably look a bit ugly.
      2) The glazing over the black box is to trap the heat inside - for example a vacuum tube collector is better under cold conditions than a flat plate collector. Vacuum is a good insulator - once the light enters the tube and contacts the collecting surface little escapes back out.
      3) There are perforated metal walls used as collectors - a double wall arrangement where the heat collected flows up between the two plates.
      • #4
        KISS Fix or add to the ductwork, or possibly balance the air going to the other part of the house to force more to the problem area.
