Actually the previous poster is apparently a salesman/woman that does not know what they are selling - there are reasonably well defined standards if one wants to search the net a bit.
LED Lights
Actually, there is, it's KELVIN, and you even reference it. The "names of color" also are pretty standardized too. warm white = 2700KYes, what you mean is color temp, but the temp of the light.
Actually, different factories have different stardards for the color temp.
Some just use warm white, day white and cool white to define the color. Also the factory can make the kelvin according to your need. There don't seem to have a Unified stardard.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
LED lights
We put LED lights in our recessed cans in the kitchen and dining room. Cree LR-6 lights are what we went with. As far as I have been able to find, they are the only commercially available LED lights with excellent color rendering (CRI> 90). They are expensive though - about $90 per light. There are many discussions about LED lights in the lighting section of the forum. Good luck!Comment
LED lights
I currently work for a company that does architectural outdoor lighting and street lighting. Right now I'm overseeing their LED projects. As it stands there are a couple of problems when trying to integrate LED's into street lighting.
First of all we are having major overheating issues when trying to retrofit existing street lamps to make them accept LED technology. To manage overheating LED's are under driven to 1 watt per LED since LED's become more efficient with lower drive currents.
solunagreen.com
Mod note - Forget the soluna green link
[/URL]Comment
I know a little about LED light
I know a little about LED light.Which country you'd like to know?Comment
Led
Try ROBUS they make heavy duty LED units, i have an LED wall washer, it makes the garden look like a spaceship!
they are heavy duty and extremely robust!
Kind regardsComment
LED lighting issues
I am astonished to read of "overheating" problems with LED lights. On of the reasons why LEDs are so efficient as compared with incandescent lights are that they converts almost all the current to light, producing virtually no heat, as compared to incandescents where heat is a major by-productComment
I think grow lights are usually used for indoor gardening, plant propagation and food production, including indoor hydroponics and aquatic plants. Although most grow lights are used on an industrial level, some small-scale/domestic usage of these lamps has also been found. Mod note - forget the spam linksComment
Dogsbody. believe it,overheating IS a problem with LEDs. Due to their very small size its difficult to get the heat away from ones above 3w. That is why they have to be mounted on heatsinks. Failure to mount them on an adequate well ventilated heatsink will reduce their life dramatically.
I am corrected. Most of the LEDS which I have used are about 125 milliwatt. I did not know that they had cranked them up to over 3 watts. In that case I can fully understand that they would need heatsinks, because diodes tend to change their properties when hot! (Like not work)Comment
The countries where summers season comes longer and hotter than winter Season.I think that Led Bulb dont work well there.That is why we dont find for LED bulbs in those countriesLast edited by Naptown; 02-29-2012, 01:30 PM. Reason: Nice try on sneaking in a link If you want to advertise contact our sponsor SolartownComment
Just put LED lamps along the drive and was curious about power consumption.
The lamps are to provide light for walking and do that nicely. There are 9 lamps with 6 LED each and 1 with 12 LED.
Power consumption is 0.29 to 0.3 amps at 230 volts or about 69 watts for the 66 lamps.
I am quite happy with the arrangement.[SIGPIC][/SIGPIC]Comment
Sounds good Russ.Last edited by dazarooney; 09-03-2012, 06:35 AM.[url]http://www.ecoledlight.co.uk/[/url]Comment
If you have 25% efficiency from an LED (beyond what is currently available in most frequencies) that still means that you are dissipating three times as much power as you get out in the form of light. Also, there will be some amount of additional heat loss in the driver / current control circuitry.I am astonished to read of "overheating" problems with LED lights. On of the reasons why LEDs are so efficient as compared with incandescent lights are that they converts almost all the current to light, producing virtually no heat, as compared to incandescents where heat is a major by-product
25% is extremely high relative to incandescent (hovering around 2%) though!SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
