I would like to know if I am on track with this little project.
I found some 1 watt 12 volt waterproof lights I would like to use for deck & garden.
Here is what I have planed so far.
Load:
4 lights at 10 hours per day for 40 Watt hours.
Charge controller:
10A Solar Lighting Controller (EPRC10-EC) dusk to dawn light control with PWM charge mode.
Battery:
12v 22Ah Electric Scooter Battery (UB12220)
Panel:
Solar Panel 85 Watt 12 Volt Multicrystalline Silicon PV
Wire:
22 gauge speaker wire, not sure about this.
Hopefully if this works well I could add 4 lights with a second battery. Any thoughts if this will work?
Load:
Charge controller:
Battery:
Panel:
Wire:
Jump up to 48 volts and it only requires about 2 amps and you can use the cheap 14 AWG with only a 4% loss in power and voltage. Up size to 10 AWG and you are under 2% loss.
