Solar powered LED Strip for home lighting.
Is your source regulated?
If the source is regulated, any 12VDC frexible strip will do very well. The store I work in sells the heck out of it 'cause it is cersatile, dimmable and easy for beginners to work with.Comment
The CRI index for the husband of a tetrachromat is still not good enough.
My next job will be to create a RGB 3 channel LED circuit board with 3 or 6, 1 watt LEDs so I can mix the colors to get true white, that dims to an amber color, like incandescents do.Last edited by Mike90250; 07-28-2011, 07:04 PM.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
That is one of the few articles I have read that did not try to sugar coat the efficiency and used real numbers including the driver power consumption. Probable not stated in terms laymen will catch or understand, not does the article point it out th efficiency is in a range of 24-50 l/w. To put that in terms most can understand is it is only slightly better than a plain ole incandescent Edison bulb, and less than CFL. It falls way short, 24 to 50% of fluorescent tube types which come in @ 100 l/w.
MSEE, PEComment
Looks a little to blue for me.. I would use ones that are closer to white . but not those yellow looking "soft white".Comment
I have both and lost two LEDs due to overheating - probably cheap ones (not cheap to buy unfortunately).Originally posted by rgs03833They only looked a little BLUE on PIX, but if you notice on top of the AC Power Plate, the Plate is White which the LEDs does make it White. You don't see it in real life...
By far i'm a lot happier than the CFL Bulbs
CFL Bulbs = HOT inverters and FIRE maybe? = YUCK!
I have yet to lose a single CFL the past four years - proper installations in two new homes. All T5 florescent lamps are doing fine. Incandescents only used for motion activated lamps and have replaced one bulb there.
I plan to install driveway illumination (very low level) using LED fixtures in the near future - will be interesting to monitor them for power consumption and all.[SIGPIC][/SIGPIC]Comment
What are you talking about? Nothing should be hot.Originally posted by rgs03833CFL Bulbs = HOT inverters and FIRE maybe? = YUCK!MSEE, PEComment
Well mabe in theory nothing should be hot.. but I have felt some cheap CFLs and the base is too hot to touch.. I have found Philips ones to run the coolest.Comment
LED Strips Lights provide business and home owners with a wide range led strip offer innovative and cost effective ways led strips are economical, environmentally and far less expensive to maintain than traditional lighting options.Comment
