I decided to make own 24 volt DC led light. I strongly believe I need help
Here is my calculations
this is the leds that I am going to buy on ebay: http://www.ebay.com/itm/1W-3W-High-P...M8s4suvIuWUQ2w
DC Forward voltage : 3,2 volt to 3,4 volt
Current: 700 mA
Because I want to make 60 watts led light I am going to use 60 of led diode (because it says each one of them is 1 watt)
According to my research I can not exceed 24 volt constraits in paralel and I need to use resistor for current limitation.
Amount of Led that I can use in series : 24 Volt / 3.4 Volt = 7.05 = 7 Led Diode in series
*Because light is going to be 60 watt lets use 6 led diode in series so it is going to be 10 paralel strings
KVL for determining resistor in every string=
- 24 V + 6 (diodes) x 3.4 volt + 700 mA x R = 0
R = 5.14 ohm is the resistor that every paralel string requires
Is my calculation is correct ? Do I need to use LED driver or something else ?
Thank you
Current: 700 mA
Thank you
