12V DC wiring for LEDs around the house (for solar use)
That will be a big mistake. You batteries will NOT stay balanced. If you want 12 volts from 24 volts get a DC to DC converter.
Also, as I mentioned previously, the voltage of a 12 volt battery varies quite a bit depending on the charge-discharge cycle. With a DC to DC converter you will have an unvarying 12 volt supply.
--mapmakerob 3524, FM60, ePanel, 4 L16, 4 x 235 watt panelsComment
