Home lighting
That is one strange answer -Depending upon the Light consumed at home, the total estimation of the light energy required by you must be done in terms of kWh. After the estimation is done,you must calculate your budget and compare it with the prices of the various battery sources available in the market that are useful for you. I use the inverter batteries and an inverter to store the power. It is useful and lasts for around one and a half day. I think you must use the inverter and inverter batteries to fulfill your power saving issues.
- What are inverter batteries?
- How do you use an inverter to store power?
- What lasts around one and a half day?Leave a comment:
You can get a variety of Battery source
Depending upon the Light consumed at home, the total estimation of the light energy required by you must be done in terms of kWh. After the estimation is done,you must calculate your budget and compare it with the prices of the various battery sources available in the market that are useful for you. I use the inverter batteries and an inverter to store the power. It is useful and lasts for around one and a half day. I think you must use the inverter and inverter batteries to fulfill your power saving issues.Leave a comment:
A good discussion is going.. Interrupted by .. S.........Leave a comment:
Me thinks you need to change your username from Udit to Idiot.Originally posted by UditAs we know even in the dark, we can generate the solar power energy.Leave a comment:
Darn, I've been aiming my panels at the sun all this time.Originally posted by UditHello Members,
As we know even in the dark, we can generate the solar power energy. .....Leave a comment:
What blather - this is research stuff and not anything done commercially.Originally posted by UditHello Members,
As we know even in the dark, we can generate the solar power energy. This was discovered by the Scientists Timothy Kucharski. Many of the people don't know how it actually works, but this was the very important invention for the used of cheap energy.
Do not post such BSLeave a comment:
Wisdom from Mumbai? Please try to do a bit better than that!Originally posted by UditTry to figure out your need of power and than accordingly purchase batteries. Its better to consult with technical person.Leave a comment:
Yes, kWh... sorry.
A few people have claimed that with an inexpensive source of batteries and maximizing the output per battery dollar in unconventional ways they can get as low as 50¢ per kWh (The H is important!) in the long haul.
But for more conventional system designs, as implemented by people whose data I believe, and paying low retail price for the equipment and batteries, the cost will be somewhere above $1.00 per kWh and often $2.00 or higher.
I rest my case.
PS: These numbers are based on AC loads and include the cost and efficiency penalty of an inverter.Leave a comment:
Interesting Sunking... What do you rate the KW cost of off-grid lighting? How would you compare it to Hawaii's 37¢ - 45¢ per KW?Leave a comment:
LED's are ok but a "street light" inside the home is total BS.
This post looks like the beginning of an advertisement or spam.Leave a comment:
It is a very good way to produce cheap light with solar system. We can save our light to use it. Here I want to ask that how much money will spend to start this work? I also want to use solar energy. Hope you will guide me soon.
Mod note - no more links or you will be bannedLeave a comment:
I suggest you use LED lights, because it is more power.
