Nope close enough
All C/10 means where C = the battery capacity expressed in Amp Hours. Your battery is rated @ 2000 ma or 2 amps. 10 or any number is the charge rate of 10 hours, or ho wmuch current is required to fully recharge a discharged battery. So to find the amount of current required to recharge a battery in 10 hours all we are doing is factoring out th etime element to leave us the current. A = AH / H, so 2 AH / 10 H = .2 amps.
Isc = Current Short Circuit of a solar panel. Which means assuming the panel is exposed to 1000 wh/meter squared insolation input is th eamount of current will produce when shorted out at the panel output.
Yes
Output of Solar Garden Lights from the Big Box Stores
Thanks for the quick reply, two other questions come to mind then.
Space is limited - the speaker box will only be about 10" tall and 6" wide - if I buy a 9v panel thats only 300mah - is that going to be a problem?
Im going to look up some of the terms you used.. c/10 and isc and learn me some solar goodness.
Im eyeing this panel: http://www.siliconsolar.com/9-volt-3...-p-501643.html
Is it Ok to be charging while it discharges?Leave a comment:
Easy Peasy. Forget the landscape light. Since you have NiMh battery you can safely charge them with a constant current of C/10 indefinitely. So just buy a standard 12 battery panel that has a Isc of around .2 amps, which should be about a 5 watt panel.
Connect the battery directly to th epanel with a diode in series with either polarity of the panel to prevent discharging the battery at night back through the solar panel.Leave a comment:
Hey, I am looking to do some small solar projects and I was wondering if I can just buy some of the garden lights at walmart and use the panels on them.
Has anyone tested the milliamp output of any of them? I'm looking for a combination of panels that can charge a 4.8V battery pack which power a small 2x3watt Class D amplifier. I only need about 20-30 minutes of use on the amp a day - its a portable speaker for my bathroom - the back of the speaker faces a sunny window - just enough power to keep the battery topped off with 2 10-15min showers daily (fiance and I).
If the walmart panels are complete garbage is there a panel out there that would be a good match for this battery pack?
The battery is "4.8V 2000mAh Square Receiver NiMH Battery Pack" I dont want to post links as a new member.
The amp is: VMA2012 Class-D Audio Amplifier Evaluation Module (EVM) Board - its easy to google.
