Solar lighting system in our school
I'd suggest these lamps from Amazon, 1 watt LED's, using 10 SMT diodes, and a driver circuit on the backside. I have several of them, they are VERY bright
Disc Type G4 Base Side Pin 10 SMD LED
You may be able to find them locally.
Because they have a "driver circuit" on the backside of the PCB, that circuit is designed to power the LED's at full brightness, regardless of the input voltage, so they cannot be dimmed. (more photos of that on Amazon).
The internet brings global purchasing, everywhere. I'm sure these are made in china, sold in bulk to the states, resold to distributors, and mailed everywhere. If someone has a credit card at the school, It's worth a chance to try to order a couple of them.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Depends on the charge controller type being PWM or MPPT
* For PWM simply look at the panel Isc rating. The controller should be equal or greater than the ISc rating of the panel. Example a 120 watt 12 volt panel should have rating like:
Voc = 22 volts
Vmp = 18 volts
Imp = 6.6 amps
Isc = 7.0 amps
You would need a 10 amp PWM controller. FWIW the max power out of a PWM controller would be 12 volts x 6.6 amps = 80 watts.
* For a MPPT take the Vmp rating of the power and divide it by the nominal battery voltage. Using the above example 120 watts / 12 volts = 10 amps. Not with a MPPT controller the max power output would be approx 120 watts minus efficiency of the controller of around 95%. So in real life about 114 watts.MSEE, PEComment
Mike one problem I see is using the LEDs you mention is they are not mounted in anything . only come on a pcb. As they are going to be used outdoors it may be hard to find something suitable to mount them in that can also keep them cool?
Importing them will also cost an unknown amount of duty, and they would have to get spares in case of failure. its unlikely they will get them locally ,I have never seen them or similar for sale there.
I dont think you understand about credit cards. Very few people there have them.. you would be lucky to find a hanful of students in the whole country that have one. And unless you live in one of the 5 major cities in the country its almost impossible to get one, and another major problem is you have to be earning more than a teacher is to get one. If im wrong and they can get one to use mabe they can tell us.
I cant even get a credit card there as the town I live in is not an"approved " town to have a bank give you a credit card,, believe it or not.Comment
I'd not realized the CC situation was so limited. How much duty can be on a $14 light bulb ?
What about camper / RV / Truck shops ? In Japan, trucks are decked out in as many colored lights as possible! The disc bulbs are replacements for G4 base halagon lights, often used in RC campers, or likely truck cabs. Any thing can be used as a shelter for the bulb.
Since they are 1.4 watts, and have enough surface area, they need no heatsink.
Anyway, just offering ideas of something I've used and thought someone else could .Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike im not trying to criticize your help. its really hard but to explain for people to understand how it is in countries like Phils..
duty can be anything from 10% to 200% . true. and if the item looks "interesting" it may get "lost "in customs.. Trucks there dont have facylights like we do here in Aus and USA .. most have just the lights that the manufacturer put on(the bare minimum). and if broken get replaced at sometime in the future.. joke only.. they never get replaced. No one has money for doing anything except the bare minimum to a truck. well for any vehicle for that matter..tires are used until they burst when worn right through.Comment
Voc = 22 volts
Vmp = 18 volts
Imp = 6.6 amps
Isc = 7.0 amps
* For a MPPT take the Vmp rating of the power and divide it by the nominal battery voltage. Using the above example 120 watts / 12 volts = 10 amps. Not with a MPPT controller the max power output would be approx 120 watts minus efficiency of the controller of around 95%. So in real life about 114 watts.Comment
Vmp = Voltage @ max power
Voc = Voltage open circuit
Imp = Current @ max power
Isc = Current short circuit.MSEE, PEComment
international shipping is a pain in the behind but with that said, great beaches in the Philippinesclearest water and excellent people there.
definitely get a smaller controller to save money. now yah just need to figure out the racking portionComment
What rating of charge controller in amps is safe if for example I have a current of 7 A. Is 10 A enough (with the 3 A allowance) or should I get a higher rating e.g. 20 A? 30 A charge controller as everyone said is a little too much to handle the current and costs about 5000 pesos (118 $). I think 10 A would cost only 2000 pesos (47$). That's already a big saving for us.
What do you mean by racking portion?Comment
What is the significance of these 4? If ever these values are not indicated in the product, how can we measure them? Thanks!
Thanks for your compliments sir.What rating of charge controller in amps is safe if for example I have a current of 7 A. Is 10 A enough (with the 3 A allowance) or should I get a higher rating e.g. 20 A? 30 A charge controller as everyone said is a little too much to handle the current and costs about 5000 pesos (118 $). I think 10 A would cost only 2000 pesos (47$). That's already a big saving for us.
These values are the technical specifications for your solar panel. All modules should have that and is your basis to configure the rest of your systemComment
The racking = the stuff that will hold up the panel, battery and charge controller WHAT ??? you cant put the panel and the battery and controller together.. Water in controllers is not good and for best results you need the panel outdoors.Comment
make sure you get an A for all your work....
azure water.... jollibee.....Comment
Jollibee.. my favorite fast food chain.
