I bought a used panel (works fine!) recently.. It has a box on the back and a sticker from the manufacturer that indicated how it should be wired for 12 or 6 volt use, and mentioned the diode placement (if applicable) as it said. I (foolishly) assumed it meant it was installed (can't remember the wording, but seemed to indicate it was there). Long story and a possibly damaged battery later, I have discovered after opening said box, that there is no diode installed..
I've no idea what could work and what wouldn't. Example.. I 1N4148's handy. Can I use one of those, or would it fry? The diode is only there to prevent the flow of electricity in the wrong direction (IE NOT to drain the battery BACK into the panel), so that would work, right? Or would the amperage stored in the battery shred the 4148? Any advice appreciated
EDIT: I appologize, it's not a 73W panel it's a 53W - I was unable to edit the title/subject
